jQuery UI Widgets › Forums › Vue › Problem with remounting component instance
This topic contains 6 replies, has 2 voices, and was last updated by JenkeNg 4 years, 7 months ago.
I noticed that the id is randomly generated when the component is generated.
created: function () { this.id = 'jqxGrid' + JQXLite.generateID(); this.componentSelector = '#' + this.id; }
Each time you manually mount a component, a different id is generated,
{ type: "documentGroup", width: "75%", items: [ { type: "documentPanel", title: "", contentContainer: "CenterPanel", initContent: function () { let maiGridComponent = Vue.extend(MainGrid); new maiGridComponent({}).$mount("#mainGrid"); }, }, ], }
but it causes a problem. The last time the event bound to the selector will not find the selector, and an error will be reported
jqxcore.js?4485:15 Uncaught (in promise) Error: Invalid Selector - #jqxGridjqxa7ca78ce5665! Please, check whether the used ID or CSS Class name is correct. at init.b.fn.<computed> [as jqxGrid] (jqxcore.js?4485:15) at VueComponent.updatebounddata (vue_jqxgrid.vue?6f80:310) at eval (HandleMainGrid.vue?7a0d:349)
See this example
click ‘Create Grid’–>click ‘Render Data’–>click ‘Create Grid’ again
Hello JenkeNg,
The issue is that the
gridContainer
is replace with the JqxGrid the way you mount it and on the second time you create a grid it can not find it.
I have modified you Example to destroy the previous grid and add<div id="gridContainer">
again.
I think it is working fine now.Best Regards,
Martin YotovjQWidgets team
https://www.jqwidgets.comHi,Martin
Thank you for your reply, useful.
But now there is a new problem, do I know how to deal with it. Please see this example1、Click “My Page” in the menu bar to open the page
It can be found that an operation on ribbon was performed in the mounted function2、Select dropdownlist
You will find that you can’t operate this ribbonWhere did I go wrong???
Hello JenkeNg,
I have tested your Example and it is working fine. The dropdownlist successfully change the ribbon’s selected item.
I have only removed the line where you select a ribbon’s item at the end of themounted
hook. The jqxRibbon is not fully initialized there yet.Best Regards,
https://www.jqwidgets.comNo, you should do it like this
1、open”My Page”
You can select the ribbon normally when you open this page for the first time2、close “My Page”
3、open “My Page” again
This ribbon will not workHello JenkeNg,
Then, I would suggest you to use a class selector for the ribbon, like this:
$('.jqx-ribbon').jqxRibbon("selectAt", ribbonIndex);
I have updated the Example and it is working fine.
Thank you for your answer, perfect solution! -
