jQuery UI Widgets Forums Navigation Menu, Context Menu Problem with jqxMenu
This topic contains 3 replies, has 2 voices, and was last updated by  arFood 12 years, 9 months ago.
  • Problem with jqxMenu #6446
    alexlilov
    First time using jqxMenu. Following the documentation I get a jscript error :
    Object doesn’t support property or method ‘jqxMenu’ . The Implementation in my partial view (MVC 3 razor) is as described in the documentation part of the tutorial. I’m using the jquery-1.7.2.min.js – lib
    // Create a jqxMenu
    $(“#jqxMenu”).jqxMenu({ width: ‘300’, height: ’30’, mode:’horizontal’});
    Are there any know issues?
    Any suggestion please.
    Thank you in advance
    Alex
    Problem with jqxMenu #6447
    alexlilov
    The problem was solved: bad reference to the jqxcore and jqxmenu.
    Is working fine!!!!
    thanks
    Problem with jqxMenu #6951
    arFood
    I have the same problem!
    May I ask how did you fix the problem?
    Problem with jqxMenu #6966
    arFood
    Solved!
    The default template of ASP.NET includes an older version of jquery.js which overrides jquery 1.7.2 necessary for jqWidgets.
    Should delete the line near the end:
    @Scripts.Render(“~/bundles/jquery”)
