jQuery UI Widgets Forums Grid Problem with jqxGrid inside a jqxExpander
This topic contains 2 replies, has 2 voices, and was last updated by  jwu 12 years, 1 month ago.
  • jwu
    I’m trying to put a jqxGrid as the expander content. Works fine on firefox and chrome, but has problem with IE8. After the expander is collapsed, the grid can on longer expand to show up
    Could you please help?
    John Wu
    If you report an issue regarding our products, please include the following information in your post:
    – jQuery version, jQWidgets version, device type(PC, Mobile), browser name and version.
    – Please, provide step by step instructions on how to reproduce the reported issue and provide a small sample which demonstrates it.
    jwu
    Thanks for the reply!
    Through some try-and-error debugging by removing some code in my jsp page, I found that the problem was caused by some outer divs that sets the header, footer, navigation bars on my webpage, so the problem is caused by the combination of my page layout divs and the jqx widgets.
    I can’t think why the widget stops working (and only on ie8) inside my layout divs. Could you give me some points as to how to debug/pinpoint this kind of issue?
    Thanks!
    john Wu
