jQuery UI Widgets › Forums › Grid › Problem with filter with checkedList
Tagged: angular grid, filter, filtertype checkedlist, grid, jquery grid, jqxgrid, jqxgrid.filter.js
This topic contains 1 reply, has 2 voices, and was last updated by Dimitar 9 years, 2 months ago.
Hi!
I am testing with a jqxgrid. But I have a problem with the filterrow on a column with filtertype ‘checkedList’.
The code is:<script type="text/javascript" src="jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.edit.js"></script> <script type="text/javascript" src="jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript" src="jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.filter.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.edit.js"></script> <script type="text/javascript" src="jqwidgets/jqxdropdownlist.js"></script> <script type="text/javascript" src="jqwidgets/jqxcombobox.js"></script> <script type="text/javascript" src="jqwidgets/jqxgrid.sort.js"></script> <script type="text/javascript" src="jqwidgets/jqxpanel.js"></script> <script type="text/javascript"> $(document).ready(function () { LoadData(); }); function LoadData() { var Srcleveranciers = { datatype: 'json', datafields: [ { name: 'TeelerID' }, { name: 'Teeler' } ], url: 'data/getLeveranciers.php', async: false }; var daLeveranciers = new $.jqx.dataAdapter(Srcleveranciers, { autoBind: true }); var data = {}; var theme = 'classic'; var source = { datatype: "json", cache: false, datafields: [ { name: 'ID' }, { name: 'TeelerID', type: 'text' }, { name: 'Teeler', value: 'TeelerID', values: { source: daLeveranciers.records, value: 'TeelerID', name: 'Teeler' } }, ], id: 'ID', url: 'data/Artikelregels.php' }; var dataAdapter = new $.jqx.dataAdapter(source); $("#jqxgrid").jqxGrid( { editable: true, selectionmode: 'singlecell', filterable: true, showfilterrow: true, sortable: true, width: '100%', height: 350, source: dataAdapter, theme: theme, columns: [ { text: 'ID', datafield: 'ID', width: 100 }, { text: 'Teeler', datafield: 'TeelerID', displayField: 'Teeler', columntype: 'dropdownlist', filtertype: 'checkedlist', width: 200, createeditor: function (row, value, editor) { editor.jqxDropDownList({ source: daLeveranciers, displayMember: 'Teeler', valueMember: 'TeelerID' }); } } ] }); } </script> </head> <body> <div class="container"> <div id="jqxgrid"> </div> </div> </body> </html>
The checklist and dropdownlist (for editing) looks fine. But when I try to filter on that column I get the following javascript error:
TypeError: b is null
…=undefined||f==null){return}f.filter=e;b.filter=e;this.dataview.addfilter(d,e);i…
jqxgrid.filter.js
Line 7Filtering on a other textcolumn is working fine. Does anyone have an idea?
Thanks!
Hi Adjo,
Please make sure you are using the latest version of jQWidgets (4.0.0). If the issue persists, please share some sample data so that we can test your example locally and determine why the issue occurs.
