jQuery UI Widgets Forums Grid Problem with filter menu box
This topic contains 5 replies, has 2 voices, and was last updated by  Martin 7 years ago.
  • Problem with filter menu box #100008
    sathiyaseelan8
    hi,
    i have enabled filter method on my grid, but the filter menu box looks too small. Please view the image below:
    https://drive.google.com/file/d/1bVSs5mIlwTlS4Q9-5Z0nktkHYPlsD77x/view?usp=sharing
    Is there any solution for this??
    thanks.
    Problem with filter menu box #100012
    Martin
    Hello sathiyaseelan8,
    Can you please, send your code as I could not figure out what the problem could be just from the picture?
    Thank you!
    Martin
    Problem with filter menu box #100029
    sathiyaseelan8
    hi Martin,
    thank you for the reply. here is my code:
    var ticketsViewGrid = function()
    		var year 	= $('#year').val();
    		var month 	= $('#month').val();
    	        dataType: "json",
    	        dataFields: [
    	            { name: 'id', type: 'int' },
    	            { name: 'subject', type: 'string' },
    	            { name: 'username', type: 'string' },
    	            { name: 'ticket_status', type: 'string' },
    	            { name: 'priority', type: 'string' },
    	            { name: 'country', type: 'string' },
    	            { name: 'created_datetime', type: 'date' }
    	        url: '/ajax/ajaxticketsViewGrid',
    	        data: {
    	        	year: year,
    	        	month: month
    	        sortcolumn: 'id',
                sortdirection: 'desc'
    	    var dataAdapter = new $.jqx.dataAdapter(source, { async: false, autoBind: true, loadError: function (xhr, status, error) { alert('Error loading "' + source.url + '" : ' + error); } });
    	    $("#grid").jqxGrid(
    	        width: '100%',
    	        showsortmenuitems: false,
    	        /*columnmenuopening: function (menu, datafield, height) {
    	            menu.width(200);
    	          { text: 'Id', datafield: 'id', width: '5%'},
    	          { text: 'Subject', datafield: 'subject', width: '40%' },
    	          { text: 'Priority', datafield: 'priority', width: '10%' },
    	          { text: 'Country', datafield: 'country', width: '10%' },
    	          { text: 'Requester', datafield: 'username', width: '10%' },
    	          { text: 'Status', datafield: 'ticket_status', width: '10%' },
    	          { text: 'Requested Date', datafield: 'created_datetime', cellsformat: 'ddd, MMM dd, yyyy', width: '15%' },
    Problem with filter menu box #100031
    Martin
    Hi sathiyaseelan8,
    I created a demo with your code, just changing the data with a hard coded array and the filter menu is working fine.
    So, it seems that the problem is coming from somewhere else.
    Here is a link to the Demo
    Martin
    Problem with filter menu box #100034
    sathiyaseelan8
    hi martin
    i couldn’t able to see the demo. is that the correct link?
    Problem with filter menu box #100036
    Martin
    Hi sathiyaseelan8,
    I’m sorry! Can you try again, now?
    Martin
