jQuery UI Widgets Forums Chart Problem with export.php
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 8 years, 2 months ago.
  • Problem with export.php #93652
    wisog
    I’m trying to export a chart as image, but having problems on local machine.
    I have an active subscription, mounted the export.php o local, if I set the url as http://www.jqwidgets.com/export_server/export.php it all works, but if I set local file, the result file it seams to be corrupted.
    The jqwidget export server gives me a file size of 28,417 bytes
    and the local one gives 29,354 bytes, using the exact same chart ( set two button, each point to each server )
    The enviroment uses PHP 5.4.3 and the md5 value of my export.php file is b10400feb020f4327bfee4449f0de1da
    What can be wrong?
    Problem with export.php #93666
    Hello wisog,
    It is strange behavior and it is impossible.
    Also, I would like to say this server is not allowed to use.
