jQuery UI Widgets Forums Grid problem with dynamic columns
This topic contains 2 replies, has 1 voice, and was last updated by  jbrahy 10 years, 5 months ago.
  • problem with dynamic columns #64503
    jbrahy
    Hello JQWidgets Team,
    I love your products and thanks for adding the functionality for dynamic columns in grids. I am trying to send all the info to generate a grid in a single json document as shown below. The error I keep getting is, “Uncaught TypeError: #<Object> is not a function” and it’s on this line. I’m not sure what I’m doing wrong and hoping that you can point me in the right direction.
    $(“#jqxgrid”).jqxGrid({
    source: gridAdapter,
    columns: columns
    Here’s the JSON document:
        "header": [
            "Server_Name",
            "Server_Size"
        "body": [
                "Server_Name": "Server 1",
                "Server_Size": "911481"
                "Server_Name": "Server 2",
                "Server_Size": "918951"
                "Server_Name": "Server 3",
                "Server_Size": "808673"
                "Server_Name": "Server 4",
                "Server_Size": "917263"
                "Server_Name": "Server 5",
                "Server_Size": "378562"
                "Server_Name": "Server 6",
                "Server_Size": "323561"
    Here’s my javascript:
        //<![CDATA[
            var url = "/sample.json";
                url: url
                    autoBind: true,
                    downloadComplete: function (data) {
                        var header = data.header;
                        var rows = data.body;
                        var datafields = [];
                        var columns = [];
                        for (header_index = 0; header_index < header.length; header_index++) {
                            datafields[header_index] = [];
                            datafields[header_index].name = header[header_index];
                            datafields[header_index].type = "string";
                            columns[header_index] = [];
                            columns[header_index].text = header[header_index];
                            columns[header_index].datafield = header[header_index];
                            columns[header_index].width = 100;
                        var gridAdapter = new $.jqx.dataAdapter({
                            datafields: datafields,
                            localdata: rows
                        $("#jqxgrid").jqxGrid('hideloadelement');
                        $("#jqxgrid").jqxGrid('beginupdate', true);
                        $("#jqxgrid").jqxGrid({
                            columns: columns
                        $("#jqxgrid").jqxGrid('endupdate');
                    width: 850,
                    columnsresize: true
            $("#jqxgrid").jqxGrid('showloadelement');
    And here’s the HTML:
    <div id="jqxgrid">
    problem with dynamic columns #64504
    jbrahy
    It looks like it’s this section of jqx-all.js that is having problems. aq = ak.map(an)
    ak is an array with name and type defined as name: “Server_Name”, type: “string” and has map and part of the prototype of an array.
    an is an object with these properties.
    Server_Name: “Server 1”
    Server_Size: “911481”
    if (ak.map) {
        if (i.isFunction(ak.map)) {
            aq = ak.map(an)
        } else {
            var ai = ak.map.split(ag.mapChar);
            if (ai.length > 0) {
                var am = an;
                for (var aj = 0; aj < ai.length; aj++) {
                    if (!am) {
                        continue
                    am = am[ai[aj]]
                aq = am
            } else {
                aq = an[ak.map]
        if (aq != undefined && aq != null) {
            aq = aq.toString()
        } else {
            if (aq == undefined && aq != null) {
                aq = ""
    problem with dynamic columns #64505
    jbrahy
    ok, I figured it out. I was using arrays where I needed objects.
    had to be
    datafields[header_index] = {};
    columns[header_index] = {};
