jQuery UI Widgets Forums Grid problem with date format
This topic contains 2 replies, has 2 voices, and was last updated by  gusanomaly 10 years, 5 months ago.
  • problem with date format #66323
    gusanomaly
    I’m using this grid with many colums, in one is width date format seted as format: ‘dd/MM/yyyy’.
    When open the grid width data from database no use the format that I seted, the date format from my database is: yyyy-mm-dd h:i:s
    So, I’ve defined in datafields like this: { name: ‘date_val’, type: ‘date’, format: ‘dd/MM/yyyy’},
    And in grid also put the next: cellsformat: ‘dd/MM/yyyy’
    When i get the data grid using getboundrows and show the data with alert() it show this: Mon Feb 02 2015 00:00:00 GMT-0300
    Thank you and i hope write clearly!
    Gustav.
    problem with date format #66325
    Hi Gustav,
    The data field’s format should be equal to your DB’s format. The column’s cellsformat should be the format which you want to be displayed. In Grid, dates are JavaScript date Object’s i.e they’re store as Mon Feb 02 2015 00:00:00 GMT-0300. If you want to get the display text of a given cell, use “getcelltext”.
    problem with date format #66358
    gusanomaly
    Works perfect!
    Thank you,
    Gustav.
