jQuery UI Widgets Forums Grid Problem with date format
This topic contains 1 reply, has 1 voice, and was last updated by  thadus 11 years, 9 months ago.
  • Problem with date format #31254
    thadus
    Hello guys!
    I’m with a problem in datetimeinput fields of a grid. When I change the values in grid, the date seems to be alright, in the format that was specified (dd/MM/yyyy HH:mm). But the value sent to server-side is in another format (something like “Tue Oct 29 2013 00:00:00 GMT-0200 (Hora oficial do Brasil)”).
    I’ve tried to make these things:
    – In source > datafields
    { name: 'inicioconsolidacao', type: 'date', format: 'dd/MM/yyyy HH:mm' }
    – In columns
    { text: 'Inicio Consolidacao',
    datafield: 'inicioconsolidacao',
    width: 140,
    columntype: 'datetimeinput',
    cellsformat: 'dd/MM/yyyy HH:mm',
    initeditor: function (row, value, editor) { editor.jqxDateTimeInput({ culture: 'pt-BR' }); }
    But doesn’t work. Have something that I made wrong?
    Thanks for support, sorry by bad english.
    Best regards.
    Problem with date format #31256
    thadus
    Another thing: I’m sending data by Ajax, with the updaterow method.
    var args = event.args;
    $(this).jqxGrid('updaterow', args.rowindex);
    url: 'inc/operacional/viagens_jd_ajax',
    data: {
    inicioconsolidacao: rowdata.inicioconsolidacao
    commit(true);
    error: function () {
    // cancel changes.
    commit(false);
