jQuery UI Widgets Forums General Discussions Layouts Splitter Problem with CSS border-top
This topic contains 2 replies, has 2 voices, and was last updated by  RichardD 13 years, 6 months ago.
  • Problem with CSS border-top #1747
    RichardD
    We are trying to integrate jsplitter in a webpage and the following CSS in our page seems to cause problem to the splitter :
    html { border-top:5px solid #FFDFB0; }
    When the bar is dragged, it will go up of 5px.
    Could you please let me know if there is a way to prevent the top-border setting to affect the splitter bar?
    Thanks in advance!
    Richard
    Problem with CSS border-top #1754
    Minko
    Blocked
    Hello Richard,
    It seems that there’s an issue with the offset() method of jQuery when is used a border on the html. We are using this method in jqxSplitter. There are two approaches for handling the issue:
    1) Using any html element which is going to simulate the same effect as a top border.
    2) Putting the splitter into iframe. The only thing that should be fixed is attaching to the parent window’s mouseup event:
    if (window.frameElement) {
    if (window.top != null) {
    $(window.top.document).bind('mouseup', function (event) {
    $(document).trigger('mouseup');
    Minko.
    Problem with CSS border-top #1755
    RichardD
    Thanks for the info Minko!
