jQuery UI Widgets Forums TreeGrid Problem with cellsRenderer property
This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 10 years, 6 months ago.
  • Problem with cellsRenderer property #63492
    Sairam
    My Tree Grid turned slow to load when I use the cellsRenderer property to return a HTML content, when the content is removed the tree grid loads pretty better. Please help.
    ` cellsRenderer: function (rowKey, dataField, value, data) {
    //debugger;
    if (data.level == 0) {
    var DisplayHTML = “” +
    “<div class=’ActivityMenu’>
    • v” +
      “<ul Group='” + dataField + “‘ RowKey = ” + rowKey + “> <li ElemId=’COPY’>Copy Value
    • <li ElemId=’PASTE’>Paste Value <li ElemId=’UPCURR’ style=’color:grey’>Upload All Values <li ElemId=’UPUPD’ style=’color:grey’>Upload Selected Values <li ElemId=’SAVE’>Save <li ElemId=’RESET’>Reset to default
    “</div>”;
    return DisplayHTML;
    else {
    return value;
    Problem with cellsRenderer property #63495
    Hi Sairam,
    If you do something which slows down the widget within the cellsRenderer, you’ll slow it down. I would suggest you to avoid doing much calculations within a function which is called for each cell.
    Problem with cellsRenderer property #63501
    Sairam
    All I do is have a menu “<div class=’ActivityMenu’>” and Hava an Img tag whick opens a popup. Is this recommended ?
    Thanks.
    Problem with cellsRenderer property #63506
    Hi Sairam,
    I don’t see a problem and why that will affect the performance then. I think that it won’t because it does not matter whether cellsRenderer is used or not unless you do something in the cellsRenderer which slows down the things.
