jQuery UI Widgets Forums Grid Problem with cell formatting
This topic contains 2 replies, has 2 voices, and was last updated by  Dimitar 11 years, 5 months ago.
  • Problem with cell formatting #50178
    wfr
    Date formatting:
    column: date
    No matter, what cellsformat I use, it always remains the same standard value (YYYY-MM-DD). I have also included type = ‘date’. The column is defined as ‘date’ in MySQL.
    Same for number format. I used the cellsformat ‘f2’ and no change in the data. The corresponding field is defined as float in MySQL as well.
    <script>
    var source ={
    { name: 'datum' },
    { name: 'bank' },
    { name: 'bank_wert' },
    { name: 'zu_an' },
    { name: 'zu_wert' },
    { name: 'info_text' },
    { name: 'info_wert' },
    { name: 'bemerkungen' },
    url: 'data.php'
    $("#jqxgrid").jqxGrid({
    source: dataAdapter ,
    theme: 'classic' ,
    width: 600 ,
    sortable: 'true' ,
    { text: 'Datum', datafield: 'datum', width: 100, type: 'date', cellsformat: 'D' },
    { text: 'Bank', datafield: 'bank', width: 50 },
    { text: 'Bank-Wert', datafield: 'bank_wert', width: 100, type: 'float', cellsformat: 'f2', cellsalign: 'right' },
    { text: 'Zahlung unterwegs an', datafield: 'zu_an', width: 200 },
    { text: 'ZU-Wert', datafield: 'zu_wert', width: 100, type: 'float', cellsformat: 'f2', cellsalign: 'right' }
    Thank you
    Walter
    Problem with cell formatting #50179
    wfr
    Ah, I just noticed, the changes only apply after editing.
    Problem with cell formatting #50201
    Hello wfr,
    You should also set the type of your datafields, i.e.:
    { name: 'datum', type: 'date' },
