jQuery UI Widgets Forums Dialogs and Notifications Window Problem with buttons in modal window
This topic contains 2 replies, has 2 voices, and was last updated by  Chris99 11 years, 10 months ago.
  • Chris99
    I have looked at your example at http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxwindow/jquery-window-events.htm?web and am trying to do something similar.
    I am having a problem with the ok and cancel buttons not closing the window (although the escape key does). I have created a fiddle at http://jsfiddle.net/Chris99/kaxSu/
    The main difference I can see between your example and mine is that I want to dynamically create the window DIVs and add them to the DOM document. I have seen this used in other posts in the forum, but the windows created did not have buttons.
    Chris
    The issue in your sample is that: defaultDialogOptions’s $(‘#ok’) and $(‘#cancel’) jQuery selections are invalid at the point you call them. You should make such jQuery selections after you append the HTML Elements that you try to select.
    Example:
    <meta name="keywords" content="jQuery Window, Window Widget, Window" />
    <meta name="description" content="With jqxWindow, you can create create multiple windows and display them at the same time on your page." />
    <title id='Description'>With jqxWindow, you can create create multiple windows and display them at the same time on your page.</title>
    <script type="text/javascript" src="../../scripts/jquery-1.10.1.min.js"></script>
    $.dm = $.dm || {};
    $.extend($.dm, {
    confirmDialog: function () {
    $("#dialog").remove();
    var dialogHtml = $("<div id='dialog'><div id='dialogTitle'>Title</div><div id='dialogContent'><div id='dialogMessage'>Hello world</div><div><div style='float: right; margin-top: 15px;'><input type='button' id='ok' value='OK' style='margin-right: 10px' /><input type='button' id='cancel' value='Cancel' /></div></div></div></div>");
    dialogHtml.appendTo(document.body);
    var defaultDialogOptions = {
    autoOpen: false,
    showCloseButton: false,
    resizable: false,
    isModal: true,
    okButton: $('#ok'),
    cancelButton: $('#cancel')
    $("#dialog").jqxWindow(defaultDialogOptions);
    $("#dialog").jqxWindow({
    'initContent': function () {
    $('#ok').jqxButton({ width: '65px' });
    $('#cancel').jqxButton({ width: '65px' });
    $('#ok').focus();
    $('#dialog').on('close', function (event) {
    return true;
    $("#dialog").jqxWindow('open');
    $("#button").click(function () {
    $.dm.confirmDialog();
    <div id="jqxWidget">
    <button id="button">
    Open popup window</button>
    Chris99
    Thanks for getting back to me so soon Peter,
    I should have spotted that one myself 😉
