jQuery UI Widgets Forums Grid Problem with addrow in grid
This topic contains 4 replies, has 2 voices, and was last updated by  priyam.basu 11 years, 7 months ago.
  • Problem with addrow in grid #46608
    priyam.basu
    When I try to add a row with an id, I seem to lose the id when I click on the row. It show up the first time I click on it, but not after that.
    I’m adding the row using var value = $(‘#TableDefinitionGrid’).jqxGrid(‘addrow’, guid(), {});
    And on $(‘#TableDefinitionGrid’).on(‘rowselect’, function (event) {
    TableFieldDefinitionID = event.args.row.TableFieldDefinitionID;
    alert(TableFieldDefinitionID );
    This shows me the ID, the first time I click on the row. But it becomes null after that.
    Problem with addrow in grid #46609
    Hi priyam.basu,
    The ID passed when you call the “addrow” method is not stored in a variable defined by you. It is internally stored in the Grid and you can access it by calling “getrowid” method.
    Problem with addrow in grid #46611
    priyam.basu
    I had tried doing
    var selectedrowindex = $(“#TableDefinitionGrid”).jqxGrid(‘getselectedrowindex’);
    alert(selectedrowindex);
    TableFieldDefinitionID = $(“#TableDefinitionGrid”).jqxGrid(‘getrowid’, selectedrowindex);
    alert(“id: ” + TableFieldDefinitionID);
    But this gives me the id of the previous selected row.
    Problem with addrow in grid #46612
    Hi priyam,
    Please, find below a sample which illustrates how to do the following:
    1. Add Row with Custom ID
    2. Select the Row with the Custom ID
    3. Get the New Row’s ID using “getrowid”
    4. Result of method call – alert with text – ‘myID’
        <title id='Description'>This example shows how to create a Grid from Array data.</title>
                var data = new Array();
                var firstNames =
                var lastNames =
                var productNames =
                var priceValues =
                for (var i = 0; i < 5; i++) {
                    var row = {};
                    row["price"] = price;
                    row["quantity"] = quantity;
                    data[i] = row;
                    localdata: data,
                    datatype: "array",
                    datafields:
                $("#jqxgrid").jqxGrid(
                    width: 670,
                      { text: 'Name', dataField: 'firstname', width: 100 },
                      { text: 'Last Name', dataField: 'lastname', width: 100 },
                      { text: 'Product', editable: false, dataField: 'productname', width: 180 },
                      { text: 'Quantity', dataField: 'quantity', width: 80, cellsalign: 'right' },
                      { text: 'Unit Price', dataField: 'price', width: 90, cellsalign: 'right', cellsformat: 'c2' },
                      { text: 'Total', dataField: 'total', cellsalign: 'right', minwidth: 100, cellsformat: 'c2' }
                $("#jqxgrid").jqxGrid('addrow', 'myID', {});
                $("#jqxgrid").jqxGrid('selectrow', 5);
                var id = $("#jqxgrid").jqxGrid('getrowid', 5);
                alert(id);
        <div id='jqxWidget'>
            <div id="jqxgrid">
    Problem with addrow in grid #46613
    priyam.basu
    Thanks you for a quick response. If I want to send data through add row, I do so in JSON format. Does it matter if my JSON has extra information in it? Because it doesnt seem to be populating the data. It adds a blank row.
