jQuery UI Widgets › Forums › React › problem with a tree populated on demand
This topic contains 4 replies, has 2 voices, and was last updated by assembler 7 years, 7 months ago.
I’m populating a tree on demand. This is a huge tree, so I only keep in memory the node which is expanded. I’m expanding and collapsing nodes constantly and the underlaying array is changing as well. So far so good.
Here comes the trouble. The tree populates itself nicely and quickly, but only renders the visible part. I mean, there is a scrollbar and it scrolls up an down but only showing the nodes that fit in the exterior tree rectangle, even truncating the letters by half. What am I missing here? Is this the correct way to do it?
constructor (props) { super(props); this.state = { tree: [] }; } componentDidMount () { JqxTree.prototype.componentDidUpdate = function (prevProps, prevState) { if (prevProps.source === this.props.source) { this.source(this.props.source); } }; // here I call the methods that populates the tree } treeRefBuilder = (r) => { this.myTree = r; } render () { return ( <JqxTree ref={this.treeRefBuilder} width={'100%'} height={'100%'} source={this.state.tree} style={{overflow: 'auto', float: 'left'}} checkboxes hasThreeStates easing={'easeInOutCirc'}/> ); }
Hi assembler,
This is normal behavior. You can add tooltips to the items so the user to read them that way. Or the other option is to use
jqxTreeGrid
and style it as a tree.Best Regards,
IvojQWidgets Team
http://www.jqwidgets.com/Mr. Ivo Zhulev
Well, I think I was not clear enough. The problem is this: I’m populating the tree, the tree has a lot of items, therefore a vertical scrollbar appears. Then, if I scroll it up or down the tree doesn’t shows the items labels, only blank. I set the checkboxes to true and it shows me these checkboxes, but not the labels. Is that a normal behavior?
Here is a link to the image: https://drive.google.com/open?id=0B3e2J2h56bKEMHlyTFhLRG5mSjg
Hi assembler,
Yes I didn’t understand you right. This is indeed a very strange behavior. Can you make a working example and share it(just the core needed code/data for it to work).
IvojQWidgets Team
http://www.jqwidgets.com/Mr. Ivo Zhulev,
I really appreciate your time, and I like JQwidgets. I found a solution, maybe no the greatest one, this is a CSS problem. In mycomponentDidMount
method I do this:let elements = $('.jqx-widget-content'); $.each(elements, function (index, value) { if (value.id.startsWith('panelContentpaneljqxTree')) { $(value).css('height', ''); return false; } });
Nevertheless here is the code:
componentDidUpdate (prevProps, prevState) { if (!isEqual(prevState.children, this.state.children)) { // here I call the method that populates the tree node on demand } } } componentDidMount () { let elements = $('.jqx-widget-content'); $.each(elements, function (index, value) { if (value.id.startsWith('panelContentpaneljqxTree')) { $(value).css('height', ''); return false; } }); this.tree.on('dblclick', () => { this.load(this.parentNode); }); this.tree.on('select', (event) => { let item = this.tree.getItem(event.args.element); this.parentNode = item.id; }); this.createFirstNode(...); } addNode (node) { // this method adds a node } lookForNode = (i = undefined) => { const id = (i ? i : this.parentNode).toString(); for (let x of this.tree.getItems()) { if (isEqual(id, x.id)) { return x; } } return undefined; } treeRefBuilder = (r) => { this.tree = r; } render () { const {width} = this.props; return ( <JqxTree ref={this.treeRefBuilder} width={'100%'} height={'100%'} incrementalSearch style={{overflow: 'auto', float: 'left'}} checkboxes hasThreeStates={this.props.checkboxes} easing={'easeInOutCirc'}/> ); }
I hope my solution could help you. Best regards!
