jQuery UI Widgets Forums Lists ListBox Problem while refreshing a listbox
This topic contains 4 replies, has 2 voices, and was last updated by  Marco 12 years, 8 months ago.
  • Problem while refreshing a listbox #7571
    Marco
    I’m using a ListBox that is bind by xml. I have a treeview in my page and when i click on items from the treeview, it refreshs the listbox.
    Here is the code called when an item of the treeview is clicked :
    function load_list(id)
    var src = getDataSource_lst(‘data_provider.php?id=’ + id);
    dataAdapter_lst = new $.jqx.dataAdapter(src);
    try
    $(“#lstBatch”).jqxListBox({ source: dataAdapter_lst });
    catch(err)
    alert(err);
    The problem is that after 8 calls, i get the following exception : “TypeError: Cannot read property ‘style’ of null” and of course, the list is not refreshed.
    Am I doing something wrong ?
    Thanks for your help,
    Marco
    Problem while refreshing a listbox #7577
    Hi Marco,
    Could you please send us a sample which reproduces that, because we are unable to do it locally? I can’t say what’s going wrong from the provided code because we have a similar working demo with jqxListBox when its source is changed dynamically.
    Problem while refreshing a listbox #7594
    Marco
    Hello Peter,
    Thanks for your reply. I have made an easy sample to reproduce the problem. You can download it here http://xbox.team.free.fr/Debug.zip
    Just run index.html and then click a lot of time on items “Link 1”, “Link 2”, “Link 3”. The exception will appears.
    I have made test under chrome and firefox 13.0.1. The version of jqwidgets is 2.4.1.
    Thanks in advance,
    Marco
    Problem while refreshing a listbox #7595
    Hi Marco,
    We tested your sample and reproduced the issue. We have been able to make a quick fix and we uploaded a new build of jqwidgets 2.4.1. You can download it from: http://www.jqwidgets.com/download/
    Problem while refreshing a listbox #7596
    Marco
    Perfect, it works fine now.
    Thanks you!
