jQuery UI Widgets Forums Grid problem while editing grid
This topic contains 3 replies, has 2 voices, and was last updated by  Dimitar 11 years, 8 months ago.
  • problem while editing grid #31057
    AhmedHamed
    hello all
    So, I’m using the grids and it’s awesome, and I’m using the edit option and it works great, and I use (editmode:’cellselection’), and it’s good, and I have another column which has a delete icon on all it’s rows, with a tooltip widget to show ‘delete row’ tool tip, and it works fine too.
    But the problem when i select the cell and start editing the tool tip on the delete icon doesn’t work any more, I have to refresh the whole page to enable it again
    Any help here ??
    Thanks In Advance
    problem while editing grid #31077
    Hello AhmedHamed,
    Please provide us with a sample code which demonstrates the reported issue.
    problem while editing grid #31154
    AhmedHamed
    Hello
    this is the sample code, as the image with class delete has the tool tip, when I just double click a cell, the tooltip doesn’t show up again
    and u can view a live demo here http://hamed.foozee.net/cabs/rooms.php
    Thanks In Advance
    <?php
    include('connect.php');
    // get data and store in a json array
    $query = "SELECT * FROM room";
    // SELECT COMMAND
    $result = mysql_query($query) or die("SQL Error 1: " . mysql_error());
    while ($row = mysql_fetch_array($result, MYSQL_ASSOC)) {
    $rooms[] = array(
    'roomsn' =>$row['ID'],
    'name' => $row['name'],
    'capacity' => $row['capacity'],
    // this is the image link which has the tool tip and it has class "delete".........................
    'delete'=>'<a href="data.php?deleteroom=true&roomsn='.$row['ID'].'"><img src="delete.png" class="delete" style="width: 20px;
    margin-left: 20px;"/></a>'
    $rooms=json_encode($rooms);
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
    <title></title>
    <link rel="stylesheet" href="style.css" type="text/css"/>
    <link rel="stylesheet" href="jqwidgets/styles/jqx.base.css" type="text/css"/>
    <link rel="stylesheet" href="jqwidgets/styles/jqx.metrodark.css" type="text/css"/>
    <link rel="stylesheet" href="jqwidgets/styles/jqx.darkblue.css" type="text/css"/>
    <link rel="stylesheet" href="jqwidgets/styles/jqx.classic.css" type="text/css"/>
    <link rel="stylesheet" href="jqwidgets/styles/jqx.shinyblack.css" type="text/css"/>
    <link rel="stylesheet" href="jqwidgets/styles/jqx.orange.css" type="text/css"/>
    <link rel="stylesheet" href="jqwidgets/styles/jqx.ui-le-frog.css" type="text/css"/>
    <link rel="stylesheet" href="jqwidgets/styles/jqx.energyblue.css" type="text/css"/>
    <script type="text/javascript" src="scripts/jquery-2.0.3.min.js"></script>
    <script type="text/javascript" src="scripts/gettheme.js"></script>
    <script type="text/javascript" src="jqwidgets/jqx-all.js"></script>
    <script type="text/javascript" src="jqwidgets/jqxgrid.selection.js"></script>
    <script type="text/javascript" src="jqwidgets/globalization/globalize.js"></script>
    { name: 'roomsn',type: 'number' },
    { name: 'name' ,type: 'string'},
    { name: 'capacity',type: 'number' },
    { name: 'delete' }
    localdata: <?php echo $rooms;?>,
    var data = "updateroom=true&name=" + rowdata.name + "&capacity=" + rowdata.capacity ;
    data = data + "&roomsn=" + rowdata.roomsn;
    dataType: 'json',
    url: 'data.php',
    data: data,
    commit(true);
    error: function () {
    // cancel changes.
    commit(false);
    $("#jqxgrid").jqxGrid({
    width: 900,
    autoheight:true,
    selectionmode: 'singlecell',
    sortable:true,
    pageable:true,
    pagesize: 15,
    enablehover: true,
    pagesizeoptions: ['10', '15', '20'],
    showfilterrow: true,
    source: source,
    theme: 'classic',
    { text: 'Room SN.', editable: false,filtertype:'textbox', datafield: 'roomsn' },
    { text: 'Room Name', columntype: 'name',filtertype:'textbox', datafield: 'name' },
    { text: 'Capacity', columntype: 'numberinput',filtertype:'textbox', datafield: 'capacity' },
    { text: 'Delete',selectionmode:'none',width:70,enablehover: false, editable: false,filterable: false,sortable:false, datafield: 'delete'
    $(".delete").jqxTooltip({ position: 'top', content: 'Delete Room', theme:'metrodark',
    autoHide:true,autoHideDelay: 9999999999 });
    <body>
    <div id="jqxgrid"></div>
    problem while editing grid #31156
    Hi AhmedHamed,
    Unfortunately, jqxTooltip cannot be used for grid cells.
