jQuery UI Widgets › Forums › Angular › Problem to display the data using Angular 5
This topic contains 1 reply, has 2 voices, and was last updated by Ivo Zhulev 7 years, 6 months ago.
I have a little issue in my jqxGrid.
I’m using a VB’s Web API and its return to me a JSON data.<string xmlns="http://schemas.microsoft.com/2003/10/Serialization/"> [{"Codigo_Cotacao":1,"itcmCodigo_Mercadoria":1,"itcmDescricao":"Anador","itcmQuantidade":2,"itccValor":10.50,"itccObservacoes":"Teste"},{"Codigo_Cotacao":1,"itcmCodigo_Mercadoria":2,"itcmDescricao":"Paracetomol","itcmQuantidade":2,"itccValor":0.00,"itccObservacoes":""}] </string>
The problem is: when I put the Web API’s link in url, its return to me a 270 empty rows, however, when I use local json-server, the information are displayed.
What should be the problem?Source and Adapter Code
this.source = // tslint:disable-next-line:one-line { datatype: 'json', datafields: [ { name: 'Codigo_Cotacao', type: 'number'}, { name: 'itcmCodigo_Mercadoria', type: 'number' }, { name: 'itcmDescricao', type: 'string' }, { name: 'itcmQuantidade', type: 'number' }, { name: 'itccValor', type: 'number'}, { name: 'itccObservacoes', type: 'string'} ], url: <code>${COTACAO_API}/api/Itens_Cotacao_Mercadoria?codigo_cotacao=${codigo_cotacao}</code> }; this.dataAdapter = new jqx.dataAdapter(this.source, { formatData: function (data) { return {}; }, loadError: function (jqXHR, status, error) { // console.log("loadError> jqXHR = " + jqXHR); console.log('loadError> jqXHR.responseText: ' + jqXHR.responseText); console.log('loadError> jqXHR.getResponseHeader: ' + jqXHR.getResponseHeader); console.log('loadError> jqXHR.getAllResponseHeaders: ' + jqXHR.getAllResponseHeaders); console.log('loadError> status = ' + status); console.log('loadError> error = ' + error); }, downloadComplete: function (data, textStatus, jqXHR){ console.log(data) } })
*The download complete returns me a JSON data, same as posted.
KelseyHi kelsey,
First of all, are you sure the API returns the data as intended?
IvojQWidgets Team
