jQuery UI Widgets Forums General Discussions Problem resulting from cell rendering
This topic contains 10 replies, has 3 voices, and was last updated by  Peter Stoev 7 years ago.
Viewing 11 posts - 1 through 11 (of 11 total)
  • Problem resulting from cell rendering #60890
    pramilkprince
    When cell render method is used in Jqxgrid , jqx cell formatting,sorting of numbers and cellalign is not working. This bug is also visible official Jqx example
                var data = new Array();
                var firstNames =
                var lastNames =
                var productNames =
                var priceValues =
                for (var i = 0; i < 100; i++) {
                    var row = {};
                    row["price"] = price;
                    row["quantity"] = quantity;
                    data[i] = row;
                    localdata: data,
                    datatype: "array"
                var cellsrenderer = function (row, columnfield, value, defaulthtml, columnproperties) {
                    if (value < 20) {
                        return '<span style="margin: 4px; float: ' + columnproperties.cellsalign + '; color: #0000ff;">' + value + '</span>';
                    else {
                $("#jqxgrid").jqxGrid(
                    width: 670,
                    source: source,
                      { text: 'Quantity', datafield: 'quantity', width: 80, cellsalign: 'right', cellsrenderer: cellsrenderer },
    <blockquote>{ text: 'Unit Price', datafield: 'price', width: 90, cellsalign: 'right', cellsrenderer: cellsrenderer, cellsformat: 'c2' },</blockquote>
                      { text: 'Total', datafield: 'total', cellsalign: 'right', cellsformat: 'c2' }
    described in page
    http://www.jqwidgets.com/jquery-widgets-documentation/documentation/jqxgrid/jquery-grid-cellsrendering.htm
    Problem resulting from cell rendering #60892
    Hi pramilkprince,
    I would like to let you know that this is not a bug. “cellsrenderer” overrides the built-in rendering. This means that you should manually render the cell’s html content. This is the general idea of “cellsrenderer”. It should be used smartly and only when it is necessary.
    Problem resulting from cell rendering #60893
    pramilkprince
    I need cellrendering method and also number sorting in that cell. Have any solution please share with me
    Problem resulting from cell rendering #60895
    Hi pramilkprince,
    If you need sorting, then I would suggest you to see the demos which implement sorting and use the same approach. You will need to include jqxgrid.sort.js and set the Grid’s sortable property to true.
    Problem resulting from cell rendering #60897
    pramilkprince
    For your knowledge , I also specify statement in your example
    { text: ‘Unit Price’, datafield: ‘price’, width: 90, cellsalign: ‘right’, cellsrenderer: cellsrenderer, cellsformat: ‘c2’ }
    Have you noticed any use cellsformat: ‘c2’ in the above statement
    Problem resulting from cell rendering #60899
    pramilkprince
    I have implemented sorting as described in your demo. But sorting of numbers is not working when using cell rendering
    Problem resulting from cell rendering #60900
    Hi pramilkprince,
    It seems that you don’t read my posts. “cellsrenderer” overrides the built-in rendering of Grid cells. “cellsrenderer” should be used when you want to display custom content in your cells. Here’s a working demo with custom rendering function and sorting: http://jsfiddle.net/jqwidgets/233fakap/. Both work pretty good.
    Problem resulting from cell rendering #60923
    pramilkprince
    Have you inspect how 10 and 5 arranged when sorting is done in ascending order
    Problem resulting from cell rendering #60928
    Hi pramilkprince,
    The sample I sent you is tested and works fine. I would suggest you to look at it.
    Following is the scenario where cell rendering is working but sorting is not working as expected, Please let me know in case any workaround or I’m missing some configuration.
    e.g. In JQXGrid : coulmn – TypicalID#(number) (Cell render will make it as hyperlink TypicalID)
    cellrender is working fine. but when we do sorting its doing sorting on the base of hyperlink text(string) but it should do with the TypicalID# (integer number).
    hemen
    Hi Hemen,
    Cell rendering overrides the built-in rendering. sorting is always by the data cell value, not by the text or html displayed in the cell.
