jQuery UI Widgets Forums Angular Problem Reseting Datetimeinput Range
This topic contains 1 reply, has 2 voices, and was last updated by  Yavor Dashev 3 years, 9 months ago.
  • Problem Reseting Datetimeinput Range #120781
    Dragday
    Hello
    I want to reset my date time input , with selectionMode of range.
    However using reactive forms, it doesn’t seem to work propertly when I have a maxDate and minDate.
    If I do:
    formControl.reset()
    The calendar starts showing NaN
    and if I do
    formControl.setValue({})
    The disabled dates wont be grayed out with the disabled class the first time you open it.
    Simple way to reproduce it, is by setting the maxDate to “new Date()” , and add a timeout on ngOnInit
      ngOnInit() {
        setTimeout(
            this.fc.setValue({})
          }, 500
    Errors
    Is this a bug? How do I properly reset a date time input range, with max dates?
    I’ve also tried setRange and val(null,null)
    Problem Reseting Datetimeinput Range #120785
    Yavor Dashev
    Hi Dragday,
    Thank you for the detailed information and code snippet!
    I was able to reproduce the exact same scenario and this is definitely a bug and a work item is added for it.
    We will work to fix it as soon as we are able to!
    Yavor Dashev
    https://www.jqwidgets.com
