I have a problem where if I have multiple jqxDropDownLists defined on a page (all initialized using Knockout) and if they start off with the same index selected, then when I update the Knockout ViewModel only one of the dropdowns is updated. Here is my code (minus jqwidgets + knockout library references):
<script type="text/javascript"> var list = [ { ID: "Item1", Description: "Item 1" }, { ID: "Item2", Description: "Item 2" }, { ID: "Item3", Description: "Item 3" } ]; var ViewModel = function () { var self = this; self.dropdown1 = ko.observable(0); self.dropdown2 = ko.observable(0); self.dropdown3 = ko.observable(0); self.resetAll = function () { self.dropdown1(0); self.dropdown2(0); self.dropdown3(0); } } var myVM = new ViewModel(); $(function () { ko.applyBindings(myVM); })</script><div data-bind="jqxDropDownList: { source: list, selectedIndex: dropdown1, valueMember: 'ID', displayMember: 'Description', height: 30, width: 100}"></div><div data-bind="jqxDropDownList: { source: list, selectedIndex: dropdown2, valueMember: 'ID', displayMember: 'Description', height: 30, width: 100}"></div><div data-bind="jqxDropDownList: { source: list, selectedIndex: dropdown3, valueMember: 'ID', displayMember: 'Description', height: 30, width: 100}"></div><input type="button" data-bind="click: resetAll" value="Reset" />
Thank you.
