This topic contains 1 reply, has 2 voices, and was last updated by  Martin 7 years ago.
  • Problem of jqxInput width #100190
    sizzflair
    I found problem ‘jqxInput’ with 5.7.2 version.
    CSS calc() function is not applied in width property.
    Please check the following sources.
    <html lang=”en”>
    <title id=’Description’>The sample illustrates the basic functionality of the jqxInput widget. The jqxInput widget provides suggestions while you type into the field. The datasource is a simple JavaScript array, provided to the widget using the “source” property. </title>
    <meta http-equiv=”X-UA-Compatible” content=”IE=edge,chrome=1″ />
    <meta name=”viewport” content=”width=device-width, initial-scale=1 maximum-scale=1 minimum-scale=1″ />
    <script type=”text/javascript” src=”../../scripts/jquery-1.12.4.min.js”></script>
    <script type=”text/javascript” src=”../../jqwidgets/jqxinput.js”></script>
    <body class=’default’>
    <div id=’content’>
    //it works(width: 200)
    $(“#input1”).jqxInput({ height: 25, width: 200 });
    //it works(width: ‘calc(100%)’)
    $(“#input2”).jqxInput({ height: 25, width: ‘calc(100%)’ });
    //it doesn’t works(width: ‘calc(100% – 30px’)
    $(“#input3″).jqxInput({ height: 25, width: ‘calc(100% – 30px)’ });
    <input type=”text” id=”input1″/>
    <input type=”text” id=”input2″/>
    <input type=”text” id=”input3″/>
    sizzflair.
    Problem of jqxInput width #100223
    Martin
    Hello sizzflair,
    Yes, this is because jqxInput’s width property is of type Number/String and it evaluates the calc function as a string.
    You can still set the input’s width with calc() in the css.
    Martin
