jQuery UI Widgets Forums Grid Problem jqxgrid nested
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 11 years, 3 months ago.
  • Problem jqxgrid nested #53697
    kenio
    hello,
    i have a problem using jqxgrid:
    i used the jqxgrid for having three levels. The first two level is ok the third lost data.
    Can you help me please?
    This is my code :
    var url = “PHP/Metadati_qualita_gen.php?metadati=RaggruppProject”;
    { name: ‘PROJECT’ },
    { name: ‘L1’, type: ‘number’ },
    { name: ‘L2’, type: ‘number’ },
    { name: ‘L3’, type: ‘number’ },
    { name: ‘L4’, type: ‘number’ },
    { name: ‘TOTALE’, type: ‘number’ },
    //async: false,
    url: url
    var orderdetailsurl = “PHP/Metadati_qualita_gen.php?metadati=RaggruppCategory”;
    var ordersSource =
    { name: ‘CATEGORY’ },
    // root: “DATAMART”,
    // record: “DATAMART”,
    url: orderdetailsurl,
    async: false
    var orderdetailsurl2 = “PHP/Metadati_qualita_gen.php?metadati=RaggruppJob”;
    var ordersSource2 =
    { name: ‘JOB’ },
    url: orderdetailsurl2,
    async: false
    var employeesAdapter = new $.jqx.dataAdapter(source, { autoBind: true });
    var ordersDataAdapter = new $.jqx.dataAdapter(ordersSource, { autoBind: true });
    var ordersDataAdapter2 = new $.jqx.dataAdapter(ordersSource2, { autoBind: true });
    var orders2 = ordersDataAdapter2.records;
    // console.log(orders2);
    var nestedGrids2 = new Array();
    // create nested grid.
    var initrowdetails2 = function (index, parentElement, gridElement, record ) {
    var id = record.uid.toString();
    //console.log(id);
    var grid = $($(parentElement).children()[0]);
    nestedGrids2[index] = grid;
    var filter_or_operator = 1;
    var filtervalue = id;
    var filtercondition = ‘equal’;
    var filter = filtergroup.createfilter(‘stringfilter’, filtervalue, filtercondition);
    // fill the orders depending on the id.
    var ordersbyid2 = [];
    for (var m = 0; m < orders2.length; m++) {
    var result = filter.evaluate(orders2[m][“CATEGORY”]);
    //console.log(orders2[m][“CATEGORY”]);
    if (result)
    ordersbyid2.push(orders[m]);
    var orderssource2 = { datafields: [
    { name: ‘JOB’ },
    localdata: ordersbyid2
    console.log(orderssource2);
    var nestedGridAdapter2 = new $.jqx.dataAdapter(orderssource2);
    if (grid != null) {
    grid.jqxGrid({
    source: nestedGridAdapter2, width: ‘60%’,
    theme: ‘darkblue’,
    showaggregates: true,
    altRows: true,
    selectionmode: ‘singlecell’,
    showstatusbar: true,
    //enablebrowserselection: true,
    // autoheight: true,
    height: 150,
    { text: ‘JOB’, dataField: ‘JOB’,minwidth: 200},
    { text: ‘L1 COMPLETEZZA’, dataField: ‘L1’,width: 100,aggregates: [‘sum’],
    aggregatesrenderer: function (aggregates) {
    var renderstring = “”;
    $.each(aggregates, function (key, value) {
    //var name = ‘TOTALE’;
    renderstring += ‘<b>Totale : ‘ + value+ ‘ </b>’;
    return renderstring;
    { text: ‘L2 INTEGRITA’, dataField: ‘L2’,width: 100,aggregates: [‘sum’],
    { text: ‘L3 BUSINESS’, dataField: ‘L3’,width: 100,aggregates: [‘sum’],
    { text: ‘L4 CONVERSIONE’, dataField: ‘L4’,width: 100,aggregates: [‘sum’],
    { text: ‘Totale’, dataField: ‘TOTALE’,aggregates: [‘sum’],
    var orders = ordersDataAdapter.records;
    // console.log(orders);
    var nestedGrids = new Array();
    var initrowdetails = function (index, parentElement, gridElement, record) {
    nestedGrids[index] = grid;
    var ordersbyid = [];
    for (var m = 0; m < orders.length; m++) {
    var result = filter.evaluate(orders[m][“PROJECT”]);
    //console.log(orders[m][“PROJECT”]);
    if (result)
    ordersbyid.push(orders[m]);
    var orderssource = { datafields: [
    var nestedGridAdapter = new $.jqx.dataAdapter(orderssource);
    if (grid != null) {
    grid.jqxGrid({
    source: nestedGridAdapter, width: ‘90%’,
    theme: ‘darkblue’,
    altRows: true,
    rowdetails: true,
    initrowdetails: initrowdetails2,
    rowdetailstemplate: { rowdetails: “<div id=’grid’ style=’margin: 20px;’></div>”, rowdetailsheight: 200, rowdetailshidden: true },
    height: 150,
    { text: ‘CATEGORY’, dataField: ‘CATEGORY’,minwidth: 250},
    { text: ‘L1 COMPLETEZZA’, dataField: ‘L1’,width: 150,aggregates: [‘sum’],
    { text: ‘L2 INTEGRITA’, dataField: ‘L2’,width: 150,aggregates: [‘sum’],
    { text: ‘L3 BUSINESS’, dataField: ‘L3’,width: 150,aggregates: [‘sum’],
    { text: ‘L4 CONVERSIONE’, dataField: ‘L4’,width: 150,aggregates: [‘sum’],
    // SECONDA GRIGLIA
    // creage jqxgrid
    $(“#jqxgrid”).jqxGrid(
    width: ‘100%’,
    theme: ‘darkblue’,
    source: source,
    rowdetails: true,
    //autoheight:true,
    // rowsheight: 30,
    altRows: true,
    { text: ‘PROJECT’, dataField: ‘PROJECT’,minwidth: 250},
    <div id=”jqxgrid” > </div>
    Problem jqxgrid nested #53702
    Hello kenio,
    Please check out the tutorial Assembling N-Nested jQuery Grid. We hope it is helpful to you.
