I’ve a scenario where I get the date from database in the following format, i.e. 08.07.2013 (dd.mm.yyyy) and I’ve to set it to one of date picker field.
First, I place this value in one hidden field and then I map the same using the following properties provide by jqxWidget.
Because I’m using jsp and I couldn’t able to map the value directly so I’m doing it in this way. I can able to get the value from hidden field but no improvements. Hence I tried hot coding the value but still nothing,
Mentioned below is the code snippet for your reference,
<div class="datePicker" id="startDate" name="" value=""></div>$("#startDate").jqxDateTimeInput({width: '100px', height: '25px', theme: theme, formatString:"dd.MM.yyyy"});$("#startDate").jqxDateTimeInput('val', "10.02.2013");
But data picker field is populated only with the today’s date not the new value.
jqxdatetimeinput.js, jqxcalendar.js – File Version: v2.8.0
jqxcore – File Version: v2.8.1
Can anyone please suggest me what could be the problem?
Thanks & Cheers,
\_rssb
