jQuery UI Widgets Forums DataTable Problem in case when the string begins with a number
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 9 years, 4 months ago.
  • mkrupl
    If the string begins with a number in the table only a number will be displayed.
    info = [
    	{key: "Storage", value: "2 GB" }
    var source = {localData: info, dataType: "array"};
    $("#infoTable").jqxDataTable({
    	theme: main.skinBasedJqxTheme,
    	width: "99%",
    	height: "90%",
    	pageable: false,
    	sortable: false,
    	columnsResize: true,
    	autoRowHeight: false,
    	altRows: true,
    	columns: [   /* Here are the definitions of createEditor, initEditor and getEditorValue functions*/  ]
    In these case in the row of “Storage” displayed value will be 2.
    Thank you
    Maria
    Hi Maria,
    The dataFields array is undefined in your source object definition. It should be defined and also the “type” of each data field in the array should be set to “string”, “boolean”, “number” or “date”.
