jQuery UI Widgets › Forums › Grid › problem editing row details in jqxgrid
This topic contains 3 replies, has 2 voices, and was last updated by Peter Stoev 10 years, 6 months ago.
I can’t figure out how to get my row details fields to be editable. I’m not doing any tricky; my row details info show up fine when loaded from mysql. Other fields in the main grid can be edited without problem. The problem is that clicking on the details info does not allow me editing.
Here is how I set up my dropdown vendor list:
var dropdownListAdapter = new $.jqx.dataAdapter(vendorSource, { autoBind: true, async: false }); var vendorSource = []; for (var i=0; i < dropdownListAdapter.records.length; i++) { vendorSource[i] = dropdownListAdapter.records[i]["vendor"]; } var source = { datatype: "json", datafields: [ { name: 'device', type: 'string', sortable: 'true'}, //id or deviceId { name: 'host', type: 'string', sortable: 'true' }, { name: 'description', type: 'string', sortable: 'true' }, { name: 'vendor', type: 'dropdownlist', sortable: 'true' } ], url: 'data.php', ................ }; var initrowdetails = function (index, parentElement, gridElement, datarecord) { ................ var vendor = "<div style='margin: 10px;'><b>Vendor:</b> " + datarecord.vendor + "</div>"; ............
and here is how I initialize my grid:
$("#jqxgrid").jqxGrid( { source: dataadapter, selectionmode: 'singlecell', editable: 'true', theme: 'darkblue', width: '90%', filterable: true, showfilterrow: true, sortable: true, autoheight: true, pageable: true, virtualmode: false, rendergridrows: function(obj) { return obj.data; }, rowdetails: true, rowdetailstemplate: { rowdetails: "<div style='margin: 10px;'><ul style='margin-left: 30px;'><li class='title'></li><li>Notes</li></ul><div class='information'></div><div class='notes'></div></div>", rowdetailsheight: 200 }, initrowdetails: initrowdetails, showstatusbar: true, columns: [ { text: 'device', datafield: 'device', width: '5%', editable: false }, { text: 'host', datafield: 'host', width:' 22%' }, { text: 'Ip Address', datafield: 'ipAddr', width: '8%' }, { text: 'Description', datafield: 'description', width: '18%' } ] });
Pretty straightforward. I have other fields that I can edit just fine, so I’m wondering why my vendor field cannot be edited?
Hi kathys2151,
I don’t see any code for Editing or enabling editing in the Row Details. Row Details are HTML Element displayed in the Grid. If you want to make custom HTML Element editable, then you would have to implement something custom.
Peter StoevOk, that’s what I was wondering. Do you have any samples of this? Or am I better off going in a different direction? I get all my data in one mysql select, but don’t want to show 20 columns at once. I liked the way the row details looked, but need to be able to edit all 20 of the columns.
Thanks for your help.Hi kathys2151,
Unfortunately, we don’t have samples about custom editing of row’s details.
Peter Stoev -
