jQuery UI Widgets Forums Grid Problem combining virtual paging and aggregate
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 12 years, 7 months ago.
  • hardcode
    Hello
    I have the grid working and i have add the aggregate to sum up values. It all seems good and perfect but the problem is because of the aggregate the virtual paging does not work any more. When i take out the aggregate fields and rendering the virtual paging works good.
    what might be the problem or what am i missing ?
    am using the version 2.5
    below is my code thanks
    async:false,
    { name: 'transactionCode' },
    { name: 'tripNumber' },
    { name: 'transDate'},
    { name: 'details'},
    { name: 'shortage'},
    { name: 'amount'},
    { name: 'payment'},
    { name: 'balance'},
    { name: 'creator'},
    { name: 'product'},
    { name: 'month'}
    url: url,
    root: 'Rows',
    cache: false
    preserveSource = source;
    $("#tripGrid").jqxGrid(
    width: '100%',
    sortable:true,
    editable: false,
    pagesize:20,
    altrows:true,
    pagesizeoptions:['20', '40', '60'],
    selectionmode: 'singlerow',
    columnsheight:30,
    virtualmode:true,
    showstatusbar: true,
    statusbarheight: 60,
    showaggregates: true,
    rendergridrows: function(obj){
    return obj.data
    { text: 'Date', dataField: 'transDate', width: 120},
    { text: 'Details', columntype: 'textbox',dataField: 'details', width: 110},
    { text: 'Salary Month', dataField: 'month', width: 100, columntype: 'textbox'},
    { text: 'Trip Number', dataField: 'tripNumber', width: 110, columntype: 'textbox'},
    { text: 'Product', columntype: 'textbox', dataField: 'product', width: 100},
    { text: 'Shortage', dataField: 'shortage', width: 135, cellsalign: 'right', cellsformat: 'f2', aggregates: ['min', 'max','sum'],
    aggregatesrenderer: function (aggregates) {
    var renderstring = "";
    var name = "";
    $.each(aggregates, function (key, value) {
    if (key == 'min'){
    name = 'Min';
    }else if (key == 'max'){
    name = 'Max';
    }else{
    name = 'Total' }
    renderstring += '<div style="position: relative; margin: 4px; overflow: hidden;"><strong>' + name + ': </strong>' + value +'</div>';
    return renderstring;
    { text: 'Amount',columntype:'textbox', dataField: 'amount', width: 135,cellsformat: 'f2', cellsalign: 'right',aggregates: ['sum'],aggregatesrenderer:
    var name = "";
    if (key == 'sum'){
    name = 'Total Amount';
    renderstring += '<div style="position: relative; margin: 4px; overflow: hidden;"> <strong>' + name + '</strong><br />' + value +'</div>';
    { text: 'Payment', dataField: 'payment', width: 130, cellsalign: 'right', cellsformat: 'f2',aggregates: ['sum'], aggregatesrenderer:
    var name = "";
    if (key == 'sum'){
    name = 'Total Payment';
    renderstring += '<div style="position: relative; margin: 4px; overflow: hidden;"><strong>' + name + '</strong><br />' + value +'</div>';
    { text: 'Balance', dataField: 'balance', width: 130, cellsalign: 'right', cellsformat: 'f2',aggregates: ['sum'],
    var name = "";
    if (key == 'sum'){
    name = 'Current Balance';
    { text: 'Employee', dataField: 'creator', width: 138}
    /*grid ends*/
    Hi hardcode,
    Thanks for writing.
    Unfortunately, aggregates in virtual mode are not currently supported.
    Peer Stoev
