jQuery UI Widgets Forums Grid Problem color head json
This topic contains 2 replies, has 2 voices, and was last updated by  nostromo 6 years, 6 months ago.
  • Problem color head json #102806
    nostromo
    Dear, I have a simple grid to which I change the color of the second column header. All good when I read the data from an arrangement.
    The problem is that when I change the array data source to json, the color change in the header column does not work anymore.
    Any idea of ​​what can happen?
    Code OK with arrangement!
    var data = generatedata(50);
    var source = {
    localdata: data,
    {name: ‘firstname’, type: ‘string’},
    {name: ‘lastname’, type: ‘string’}],
    datatype: “array”
    $(“#grid”).jqxGrid(
    width: 500,
    { text: ‘FirstName’, dataField: ‘firstname’, width: 80, align: ‘center’, cellsalign: ‘center’ },
    { text: ‘LastName’, dataField: ‘lastname’, width: 90, align: ‘center’, cellsalign: ‘center’ }
    var firstNameCell = $(‘div .jqx-grid-column-header:eq(1)’);
    firstNameCell.css(‘background-color’, ‘rosybrown’);
    <body>
    <div id=”grid”></div>
    code using json, the second column color change header no longer works
    var source = {
    url: “qry_datosGrilla.cfm”,
    datatype: “json”
    $(“#grid”).jqxGrid(
    width: 500,
    <body>
    Problem color head json #102824
    Martin
    Hello nostromo,
    This happens because when you use url in the source, instead of localdata,
    your code for applying css to the header cell is executed before the grid is rendered.
    To fix this, move the code in the ready callback of the grid:
    $("#grid").jqxGrid(
       width: 500,
       ready: function () {
          let firstNameCell = $('.jqx-grid-column-header:eq(1)');
          firstNameCell.css('background-color', 'rosybrown');
          { text: 'FirstName', dataField: 'firstname', width: 80, align: 'center', cellsalign: 'center' },
          { text: 'LastName', dataField: 'lastname', width: 90, align: 'center', cellsalign: 'center' }
    Martin
    Problem color head json #102830
    nostromo
    Excellent!!!
