jQuery UI Widgets › Forums › Grid › preset drop down field and events to monitor
This topic contains 5 replies, has 2 voices, and was last updated by svetoslav_borislavov 2 years, 10 months ago.
I have a jqxGrid. The dataset powering it looks like this:
{ "duplication_control_id": 1, "duplication_control": "Demo", "duplication_control_type_id": 1, "days": 90, "duplication_control_owner_list_group_id": 1, "duplication_control_routing_rule_group_id": 1, "duplication_control_manager_list_group_id": 1, "created_at": "2022-07-13 12:33:24", "updated_at": "2022-07-13 14:11:37", "deleted_at": null }
For many of the columns I have look up tables for the values. i.e. duplication_control_type_id relates to a table called duplication_control_types with two columns. duplication_control_type_id (int) and duplication_control_type (string).
When someone edits the row/column for any of these look ups I want to display the look up value instead of the id of the look up table.
Is there a demo for this? The look-up JSON would be something like this:
[ { "duplication_control_type_id": 1, "duplication_control_type": "Allow Duplicates" }, { "duplication_control_type_id": 2, "duplication_control_type": "Global Deduplication" }, { "duplication_control_type_id": 3, "duplication_control_type": "Group Deduplication" } ]
Here’s a sample column that I’m trying to use a drop-down list column. I took a few of your examples and tried to hack them together, but I’m not finding all the documentation for events like createeditor, and cellvaluechanging.
{ text: 'Routing Rule Group', displayMember: 'routing_rule_group', valueMember: 'routing_rule_group_id', columntype: 'dropdownlist', datafield: 'routing_rule_group', width: 195, createeditor: function(row, column, editor) { // assign a new data source to the dropdownlist. editor.jqxDropDownList({ displayMember: 'routing_rule_group', valueMember: 'routing_rule_group_id', autoDropDownHeight: true, source: routing_rules_group_data_adapter, }); }, // update the editor's value before saving it. cellvaluechanging: function(row, column, columntype, oldvalue, newvalue) { // return the old value, if the new value is empty. if (newvalue == '') { return oldvalue; } }, }
These were things I tried but didn’t work.
Take a look at this example: https://jsfiddle.net/hexnz86r/.
In the example, the dataset contains a field with an id and there is also a lookup table. The grid matches the id with the appropriate label and displays it. Also when editing the ids are also matched with the lookup table.
Have a look also at this sample: https://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/index.htm#demos/jqxgrid/gridkeyvaluescolumnwitharray.htm
If you have questions or need further assistance, please let me know!Best regards,
Svetoslav BorislavovjQWidgets Team
https://www.jqwidgets.com/Thank you Svetoslav Borislavov, I think this is exactly what I’m looking for. I’m going to put it into a test and see how it works.
ok, so this is where I’m at. I definitely see the drop downs populating but I don’t see any text in them. I’m hoping that it’s just a little mistake somewhere that you can point out. I’m also going to re-read your examples and see what I can find.
<script type="application/javascript"> $(document).ready(function() { let duplication_control_types_source = { datatype: 'json', datafields: [ { name: 'duplication_control_type_id', type: 'int', }, { name: 'duplication_control_type', type: 'string', }, ], url: '/cgi-bin/duplication_control_types/dataset?rand=' + Math.random().toString(), }; let duplication_control_types_data_adapter = new $.jqx.dataAdapter(duplication_control_types_source); let publisher_group_source = { datatype: 'json', datafields: [ { name: 'publisher_group_id', type: 'int', }, { name: 'publisher_group', type: 'string', }, ], url: '/cgi-bin/publisher_groups/dataset/?rand=' + Math.random().toString(), }; let publisher_groups_data_adapter = new $.jqx.dataAdapter(publisher_group_source); let color_groups_source = { datatype: 'json', datafields: [ { name: 'color_group_id', type: 'int', }, { name: 'color_group', type: 'string', }, ], url: '/cgi-bin/color_groups/dataset/?rand=' + Math.random().toString(), }; let color_groups_data_adapter = new $.jqx.dataAdapter(color_groups_source); let product_groups_source = { datatype: 'json', datafields: [ { name: 'product_group_id', type: 'int', }, { name: 'product_group', type: 'string', }, ], url: '/cgi-bin/product_groups/dataset/?rand=' + Math.random().toString(), }; let product_groups_data_adapter = new $.jqx.dataAdapter(product_groups_source); let duplication_controls_source = { datatype: 'json', datafields: [ { name: 'duplication_control_id', type: 'int', }, { name: 'duplication_control', type: 'string', }, { name: 'duplication_control_type_id', type: 'int', values: { source: duplication_control_types_data_adapter.records, value: 'duplication_control_type_id', name: 'duplication_control_type', }, }, { name: 'duplication_control_type', type: 'string', }, { name: 'publisher_group_id', type: 'int', values: { source: publisher_groups_data_adapter.records, value: 'publishers_group', name: 'publisher_groups_id', }, }, { name: 'color_group_id', type: 'int', values: { source: color_groups_data_adapter.records, value: 'color_group_id', name: 'color_group', }, }, { name: 'product_group_id', type: 'int', values: { source: product_groups_data_adapter.records, value: 'product_group_id', name: 'product_groups', }, }, { name: 'created_at', type: 'datetime', }, { name: 'updated_at', type: 'datetime', }, { name: 'deleted_at', type: 'datetime', }, ], url: '/cgi-bin/duplication_control/dataset/?rand=' + Math.random().toString(), updaterow: function(rowid, rowdata, commit) { // synchronize with the server - send update command // call commit with parameter true if the synchronization with the server is successful // and with parameter false if the synchronization failed. commit(true); }, }; let duplication_controls_data_adapter = new $.jqx.dataAdapter(duplication_controls_source, { autoBind: true, }); $('#duplication_controls_table').jqxGrid({ source: duplication_controls_data_adapter, editable: true, width: '100%', height: '100%', theme: 'dark', columns: [ { text: 'Duplication Control', columntype: 'textbox', datafield: 'duplication_control', width: 120, }, { text: 'duplication_control_type', columntype: 'dropdownlist', datafield: 'duplication_control_type', width: 150, createeditor: function(row, value, editor) { editor.jqxDropDownList({ source: duplication_control_types_data_adapter, displayMember: 'duplicate_control_type', valueMember: 'duplicate_control_type_id', autoDropDownHeight: true, }); }, }, { text: 'Owner List Group', displayMember: 'publisher_group', valueMember: 'publisher_group_id', columntype: 'dropdownlist', datafield: 'publisher_group', width: 150, createeditor: function(row, value, editor) { editor.jqxDropDownList({ source: duplication_control_types_data_adapter, displayMember: 'duplicate_control_type', valueMember: 'duplicate_control_type_id', autoDropDownHeight: true, }); }, }, { text: 'Routing Rule Group', displayMember: 'color_group', valueMember: 'color_group_id', columntype: 'dropdownlist', datafield: 'color_group', width: 150, createeditor: function(row, value, editor) { editor.jqxDropDownList({ source: duplication_control_types_data_adapter, displayMember: 'duplicate_control_type', valueMember: 'duplicate_control_type_id', autoDropDownHeight: true, }); }, }, { text: 'Manager List Group', columntype: 'dropdownlist', datafield: 'product_groups', width: 150, createeditor: function(row, value, editor) { editor.jqxDropDownList({ source: duplication_control_types_data_adapter, displayMember: 'duplicate_control_type', valueMember: 'duplicate_control_type_id', autoDropDownHeight: true, }); }, }, { text: 'created_at', datafield: 'created_at', width: 150, }, { text: 'updated_at', datafield: 'updated_at', width: 150, }, ], }); }); </script> <div class="container"> <div class="row"> <div class="col-12"> <div id="duplication_controls_table"></div> </div> </div> </div>
Where do these come from?
datafield: 'someForeignData', displayfield: 'foreignDataLookup',
Your duplication_control_types_source, publisher_group_source, color_groups_source and product_groups_source are the sources for the lookup, so the data adapter, which you are creating should have the autoBind property set to true. You shouldn`t set the autoBind property to the duplication_controls_data_adapter.
For example:let publisher_group_source = { datatype: 'json', datafields: [ { name: 'publisher_group_id', type: 'int', }, { name: 'publisher_group', type: 'string', }, ], url: '/cgi-bin/publisher_groups/dataset/?rand=' + Math.random().toString(), }; let publisher_groups_data_adapter = new $.jqx.dataAdapter(publisher_group_source, { autoBind: true });
Next, you do not have the value to which you want to bind the data from the lookup. For example here:
This should look like for example:{ name: 'publisher_group_bound_with_lookup', value: 'publisher_group_id_from_dataset', //the id from the dataset values: { source: publisher_groups_data_adapter.records, value: 'publisher_group_id', name: 'publisher_group', }, }
Look, now you have a value from which you will bind (publisher_group_bound_with_lookup) and in the values object, I have swapped the value
s value with the name
s value.
NOTE THAT the publisher_group_id_from_dataset property should be defined as a datafield in the duplication_controls_source.Next, here:
You are trying to display a datafield that you have not defined and you are passing the wrong data adapter for the editor`s lookup table source.
Your column should look like this:{ text: 'Owner List Group', displayMember: 'publisher_group_bound_with_lookup', columntype: 'dropdownlist', datafield: 'publisher_group_id_from_dataset', width: 150, createeditor: function(row, value, editor) { editor.jqxDropDownList({ source: duplication_control_types_data_adapter, displayMember: 'duplicate_control_type', valueMember: 'duplicate_control_type_id', autoDropDownHeight: true, }); }, }
I highly suggest you review the demo I gave you!
I will wait for your feedback to let me know the result!Best regards,
https://www.jqwidgets.com/ -
