jQuery UI Widgets Forums Grid Possible aggregatesrenderer issue?
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 7 years, 10 months ago.
  • Possible aggregatesrenderer issue? #94922
    jens.gauger
    Hello dev team,
    there might by a problem with the aggregatesrenderer attribute in combination with localization. I configured the localization to use decimal and thousands separators fitting for Germany. The numeric grid cells display this format well.
    Additionally i added a custom aggregatesrenderer function following your documentation. The aggregates are being displayed, but without using the localization setting. This happens only after grid initialization! Once the grid initialization is done and i change a cell’s value, the aggregates will be computed and output with the correct localization!
    Jens
    Possible aggregatesrenderer issue? #95004
    Hello Jens,
    I try to reproduce it but it looks fine, the aggregates could be overwritten on the desired way. I cannot find the delay of changing the names.
    Could you provide us more details?
