jQuery UI Widgets Forums Chart Position of Chart Axis Values
This topic contains 1 reply, has 1 voice, and was last updated by  binfch 12 years, 11 months ago.
  • Position of Chart Axis Values #7232
    binfch
    Hi there
    This is a small cosmetic issue I have -> Pls check the following screenshot.
    Is there a way to have the x-axis values written lower in the chart? Here is my code:
    var settingsDay = {
    enableAnimations: false,
    title: '',
    titlePadding: { left: 0, top: 0, right: 0, bottom: 0 },
    description: '',
    showLegend: false,
    borderColor: '#ff0000',
    background: '#e3e3e3',
    categoryAxis: {
    dataField: 'XAxis',
    formatFunction: function (value) {
    if (value.substring(0,2) in {'05':1, '10':1, '15':1, '20':1, '25':1, '30':1}) {
    return value.substring(0,2);
    } else {
    return '';
    toolTipFormatFunction: function (value) {
    return value;
    textRotationAngle: 0,
    showTickMarks: true,
    tickMarksInterval: 1,
    showGridLines: false,
    unitInterval: 1,
    axisSize: 'auto'
    colorScheme: 'scheme01',
    seriesGroups: [ {
    type: 'column',
    columnsGapPercent: 100,
    valueAxis: {
    minValue: 0,
    maxValue: 'auto',
    displayValueAxis: false,
    axisSize: 'auto',
    series: [ {
    dataField: 'YAxis',
    displayText: 'Transactions'
    $('#tranPerDayChart').jqxChart(settingsDay);
    Thanks & cheers,
    Peter
    Position of Chart Axis Values #7233
    binfch
    Hi there
    I think I found a solution by adding:
    padding: { left: 0, top: 0, right: 0, bottom: -10 },
    Thx & cheers,
    Peter
