jQuery UI Widgets › Forums › Chart › Pie percentage and values
This topic contains 1 reply, has 2 voices, and was last updated by Dimitar 12 years, 4 months ago.
Hi
It’s possible to set a Pie chart to view the value in percentage mode in the chart and in real value in the tooltip.
Example source
a:300
b:400
c:1200
I would a pie chart with the percentage of real value a:16%, b:21%, c:63%, but in a tooltip i would see a:300, b:400, c:1200
It’s possible?
Hello marchip,
Here is an example:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html lang="en"><head> <title id='Description'>jqxChart Pie Series Example</title> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.8.2.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxchart.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript"> $(document).ready(function () { // prepare chart data as an array var source = { datatype: "csv", datafields: [ { name: 'Name' }, { name: 'Value', type: "number" } ], url: 'sample.txt' }; var dataAdapter = new $.jqx.dataAdapter(source, { async: false, autoBind: true, loadError: function (xhr, status, error) { alert('Error loading "' + source.url + '" : ' + error); } }); $.jqx._jqxChart.prototype.colorSchemes.push({ name: 'myScheme', colors: ['#ffff00', '#ff0000', '#ccffff'] }); var sumValue = 0; $.each(dataAdapter.records, function () { var current = this; sumValue += current.Value; }); // prepare jqxChart settings var settings = { title: "Items", enableAnimations: true, showLegend: false, legendPosition: { left: 520, top: 140, width: 100, height: 100 }, padding: { left: 5, top: 5, right: 5, bottom: 5 }, titlePadding: { left: 0, top: 0, right: 0, bottom: 10 }, source: dataAdapter, colorScheme: 'myScheme', seriesGroups: [ { type: 'pie', showLabels: true, series: [ { dataField: 'Value', displayText: 'Name', labelRadius: 100, initialAngle: 15, radius: 130, centerOffset: 0, formatFunction: function (value) { return (value / sumValue * 100).toFixed(2) + "%"; }, toolTipFormatFunction: function (value) { return value; } } ] } ] }; // setup the chart $('#jqxChart').jqxChart(settings); }); </script></head><body class='default'> <div id='host' style="margin: 0 auto; width: 699px; height: 400px;"> <div id='jqxChart' style="width: 680px; height: 400px; position: relative; left: 0px; top: 0px;"> </div> </div></body></html>
And here is the data in sample.txt:
a, 300b, 400c, 1200
