jQuery UI Widgets Forums Grid PHP edit grid question help
This topic contains 4 replies, has 2 voices, and was last updated by  Inverse 11 years, 2 months ago.
  • PHP edit grid question help #52442
    Inverse
    I want to be able ajax without refreshing edit
    Page does not reforming
    help me..
                var theme = 'classic';
    			   var getLocalization = function () {
                    var localizationobj = {};
                    localizationobj.pagergotopagestring = "1";
                    localizationobj.pagershowrowsstring = "2";
                    localizationobj.pagerrangestring = " 3 ";
                    localizationobj.pagernextbuttonstring = "voriger";
                    localizationobj.pagerpreviousbuttonstring = "nächster";
                    localizationobj.sortascendingstring = "Sortiere aufsteigend";
                    localizationobj.sortdescendingstring = "Sortiere absteigend";
                    localizationobj.sortremovestring = "Entferne Sortierung";
                    localizationobj.firstDay = 1;
                    localizationobj.percentsymbol = "%";
                    localizationobj.currencysymbol = "€";
                    localizationobj.currencysymbolposition = "after";
                    localizationobj.decimalseparator = ".";
                    localizationobj.thousandsseparator = ",";
                    var days = {
                        // full day names
                        names: ["Sonntag", "Montag", "Dienstag", "Mittwoch", "Donnerstag", "Freitag", "Samstag"],
                        // abbreviated day names
                        namesAbbr: ["Sonn", "Mon", "Dien", "Mitt", "Donn", "Fre", "Sams"],
                        // shortest day names
                        namesShort: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"]
                    localizationobj.days = days;
                    var months = {
                        // full month names (13 months for lunar calendards -- 13th month should be "" if not lunar)
                        names: ["Januar", "Februar", "März", "April", "Mai", "Juni", "Juli", "August", "September", "Oktober", "November", "Dezember", ""],
                        // abbreviated month names
                        namesAbbr: ["Jan", "Feb", "Mär", "Apr", "Mai", "Jun", "Jul", "Aug", "Sep", "Oct", "Nov", "Dez", ""]
                    var patterns = {
                        d: "dd.MM.yyyy",
                        D: "dddd, d. MMMM yyyy",
                        t: "HH:mm",
                        T: "HH:mm:ss",
                        f: "dddd, d. MMMM yyyy HH:mm",
                        F: "dddd, d. MMMM yyyy HH:mm:ss",
                        M: "dd MMMM",
                        Y: "MMMM yyyy"
                    localizationobj.patterns = patterns;
                    localizationobj.months = months;
                    localizationobj.todaystring = "Heute";
                    localizationobj.clearstring = "Löschen";
                    return localizationobj;
    				 cache: false,
    					 { name: 'id', type: 'string'},
    					 { name: 'status', type: 'string'},
    			        url: 'data.php',
    				cache: false,
    				filter: function()
    				sort: function()
    				root: 'Rows',
    					loadError: function(xhr, status, error)
    						alert(error);
                // initialize jqxGrid
    			    width: 520,
                    source: dataadapter,
    				selectionmode: 'multiplerows',
    				virtualmode: true,
    				showfilterrow: true,
    				rendergridrows: function(obj)
    					  return obj.data;
                      { text: 'id',  datafield: 'id', width: 80 },
    	          { text: 'status', datafield: 'status', width: 50, },
    	        $("#up").on('click', function () {
                    var selectedrowindex = $("#jqxgrid").jqxGrid('getselectedrowindex');
    					var row = $("#jqxgrid").jqxGrid('getrowdata', selectedrowindex);
                                dataType: 'json',
                                url: 'select.php',
    							data: 'id='+row.id+'&status='+row.status,
    							cache: false,
       <input id="up" type="button" value="check" />
    PHP code
    <?php
      $dbhost = 'localhost';
      $dbuser = 'root';
      $dbpass = '';
      $dbname = 'pos';
      $conn = mysql_connect($dbhost, $dbuser, $dbpass) or die('Error with MySQL connection');
      mysql_query("SET NAMES 'utf8'");
      mysql_select_db($dbname);
      if($_GET['status'] == 0){
      mysql_free_result($result);
      $sql = "update into_goods set status =1 where <code>id</code>='".$_GET['id']."'";
      $result = mysql_query($sql) or die('MySQL query error');
      else  {
      $sql = "update into_goods set status =0 where <code>id</code>='".$_GET['id']."'";
    PHP edit grid question help #52450
    Hi Roberto,
    I spotted a syntax error in your code: cache: false, – the ‘,’ should be removed, because cache: false is the last item.
    Another syntax error is: { text: ‘status’, datafield: ‘status’, width: 50, },. The ‘,’ after 50 and after ‘}’ should be removed.
    PHP edit grid question help #52483
    Inverse
    Thank you Peter Stoev
    But I want to ajax web no Refresh
    I now code is Refresh
    Please help me~
    PHP edit grid question help #52486
    Hi Inverse,
    To perform a new Ajax request using the same dataAdapter, use the jqxGrid’s “updatebounddata” method.
    PHP edit grid question help #52506
    Inverse
    Peter Stoev Thank you very much!~ヾ(*´∀`*)ノ
