jQuery UI Widgets Forums Chart Personalize Labels Color and Pie Chart Slide Color
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 12 years, 7 months ago.
  • leos1981
    Can you enhance the jqxchart so that we can personalize the label color for each bar/slide? Single color are very hard to match will all kinds of color in the bar/slide. Besides, appreciate if you can also allow us to personalize the color of slides in the pies chart.
    Example:
    series: [
    { dataField: ‘S&P 500’, displayText: ‘S&P 500’, color: ‘#ffffff’, labelColor: ‘#888888’ },
    { dataField: ‘NASDAQ’, displayText: ‘NASDAQ’, color: ‘#0ff0ff’, labelColor: ‘#888888’ }
    Thank you very much!
    Leos
    Hi Leos,
    As a solution, you may use the Chart’s labelClass property. You can set the labelClass to point to a CSS class in a serie or group.
