jQuery UI Widgets › Forums › Grid › Passing textbox values from jqgrid to controller
This topic contains 5 replies, has 2 voices, and was last updated by Vladimir 9 years, 8 months ago.
I have few textboxes like (name, city , state , country) and a submit button. I would like to pass the values of the text boxes from jqgrid to controller methods. I have my code below. The problem is I am not able to get the value of the textbox it is always empty Can you please help me in thi ssituation.
Script is as follows:
var source = {
{ name: ‘OfficeID’, type: ‘string’ },
{ name: ‘Name’, type: ‘string’ },
{ name: ‘Address’, type: ‘string’ },
{ name: ‘City’, type: ‘string’ },
{ name: ‘State’, type: ‘string’ },
{ name: ‘Country’, type: ‘string’ },
{ name: ‘PostalCode’, type: ‘string’ },
{ name: ‘StatusCd’, type: ‘string’ },
{ name: ‘UpdatedBy’, type: ‘string’ },
{ name: ‘UpdateTime’, type: ‘string’ }],
url: “@Url.Action(“OfficeList”, “SearchForOffice”)”,
data: {
Name: function() { return $(“#Name”).val(); },
City: function() { return $(“#City”).val(); },
State: “State”,
Country: “Country”}
var dataAdapter = new $.jqx.dataAdapter(source);$(“#jqxgrid”).jqxGrid(
width: 950,
autorowheight: true,
selectionmode: ‘singlerow’,
filterable: true,columns: [
//{ text: ”, datafield: ‘link’, width: 50, cellsrenderer: linkrenderer },
text: “Office ID”, datafield: “OfficeID”, width: 65
text: “Name”, datafield: “Name”, cellsrenderer: cellsrenderer, width: 150
text: “Address”, datafield: “Address”, width: 115
text: “City”, datafield: “City”, width: 85
text: “State”, datafield: “State”, width: 50
text: “Country”, datafield: “Country”, width: 60
});HTML texboxes as follows
<tr>
<td><input type=”submit” name=”Search” id=”Search” /></td>
</tr>
<tr>
<td><b>Search By</b></td>
</tr>
<tr>
<td align=”right”>
Name
</td>
<td> </td>
<td>
<input type=”text” name=”Name” id=”Name” />
</td>
</tr>
<tr>
<td align=”right”>
City
</td>
<td> </td>
<td>
<input type=”text” name=”City” id=”City” />
</td>
</tr>Controller action method as follows
public JsonResult OfficeList(string Name, string City, string State, string Country)
{list = SO.GetList();
return Json(list, JsonRequestBehavior.AllowGet);
}Hello harsh,
You are trying to add a function as the value of a json object.
Instead of adding the data you need in the ‘data’ parameter, use the formatData callback function and override the object there.
Instead of:
data: { Name: function() { return $(“#Name”).val(); }, City: function() { return $(“#City”).val(); }, State: “State”, Country: “Country” }
use
formatData: function (data){ data.Name = $(“#Name”).val(); data.City = $(“#City”).val(); data.State = “State”; data.Country = “Country”; }
Read the dataAdapter API for more information.
VladimirjQWidgets Team
http://www.jqwidgets.comHi,
I have used formatData but I am not able to pass the value entered in textboxes to controller. Its is always empty. can you please let me know wer iam going wrong.
Hello harsh,
Since you haven’t posted any code, I can only suggest to you that you place a debugger/break point in the formatData function and see if
$('#Name').val()
returns the desired value, and if not, try to find out why. Or if yes, then the problem is likely that the controller expects your data in a different way.If it is a get request, then the data may be expected in a string format and then you may actually need something like:
data = data + '&Name=' + $('#Name').val();
http://www.jqwidgets.com$(“#Name”).val() is always empty when i hit submit button.
Hello harsh,
Did you initialize the inputs using jqxInput?
.val() method is part of jqxInput, so in order for it to return any value, you need to initialize it:
$("#Name").jqxInput({ height: 25, width: 200});
