jQuery UI Widgets › Forums › Grid › Paging links beyond 28 or 36 pages is not showing up.
This topic contains 2 replies, has 2 voices, and was last updated by Zafar 12 years, 7 months ago.
Hi All,
I just run custom paging example at this link.
http://www.jqwidgets.com/jquery-widgets-documentation/documentation/jqxgrid/jquery-grid-paging.htm
If I change loop value from 100 to 400 to generate 400 pages, I cannot see paging links beyond 270 pages. i.e I see only 0-26 links.
In another scenario, in my application, I cannot see paging beyond 360 pages.
How can I fix this please, so I can have links to all pages loaded in the grid.
ZafarHi Zafar,
The sample in the help topic shows how to override the built-in pager renderer. The sample adds Anchor tag for each page. If there’s not enough space for all Anchor tags, you will not see them. I suppose that an approach with an Input field for entering the page number will be more appropriate in your scenario.
Thanks so much for the quick answer.
Also I am looking at possibility of using virtual data paging, if it runs same on android phone or tablet.
I just run the sample example but with my inputs. I could not figure out why it is not loading. Could you please help?
FYI, JsobObject is returned from server. It can 10-200000 records. Thanks so much!!
In this demo jqxGrid uses a virtualized paging which enables you to handle very large data sets without any impact on client side performance.
var theme = getTheme();
var data = new Array();
var jsonObject = { “contactList”:[{“age”:1,”SId”:”S1234567″,”gender”:”male”},
{“age”:1,”SId”:”S1234567″,”gender”:”male”},], “totalrecords”:9};
//alert(“jsonObject.totalrecords : ” + jsonObject.totalrecords);
// generate sample data.
var generatedata = function (startindex, endindex) {
var data = {};
for (var i = startindex; i < endindex; i++) {//alert(startindex + " " + endindex);
var row = {};row["age"] = jsonObject.contactList[i].age;
row["gender"] = jsonObject.contactList[i].gender;
row["SId"] = jsonObject.contactList[i].SId;data[i] = row;
return data;
datatype: "array",
localdata: {},
totalrecords: jsonObject.totalrecords
};// load virtual data.
var rendergridrows = function (params) {alert("rendergridrows : " + source.totalrecords);
//alert("rendergridrows : " + params.startindex + " " + params.endindex);
var data = generatedata(params.startindex, params.endindex);
return data;
var totalcolumnrenderer = function (row, column, cellvalue) {
var cellvalue = $.jqx.dataFormat.formatnumber(cellvalue, 'c2');
return '‘ + cellvalue + ”;
$(“#jqxgrid”).jqxGrid(
width: 670,
virtualmode: true,
columns: [{ text: ‘Age’, datafield: ‘age’, width: 50 },
{ text: ‘SId’, datafield: ‘SId’, width: 120 },
{ text: ‘Gender’, datafield: ‘gender’, width: 80 },]
