jQuery UI Widgets Forums Angular pagination for grid not working
This topic contains 3 replies, has 2 voices, and was last updated by  Hristo 5 years, 1 month ago.
  • pagination for grid not working #111465
    wpd
    grid not showing data when i am adding attribute pagesizeoptions
    <jqxGrid #jobStatusGrid [theme]=”‘whitepine'” (onCellclick)=”Cellclick($event)” [width]=”‘100%'”
    [height]=”‘100%'” [source]=”jobStatusDataAdapter” [columns]=”jobStatusColumns” [showheader]=”true”
    [pageable]=’true’ [sortable]=’true’ [filterable]=’true’ [pagesizeoptions]=”[’25’, ’50’, ’75’]” [pagesize]=”50″>
    </jqxGrid>
    it is working good when i remove this(below code is working good)
    [pageable]=’true’ [sortable]=’true’ [filterable]=’true’ [pagesize]=”20″>
    </jqxGrid>
    Any thoughts?
    pagination for grid not working #111497
    Hello wpd,
    I tested this example below and it seems to work fine:
    https://stackblitz.com/edit/github-fqjdgx
    Could you clarify it?
    Please, try to provide us with a simplified example.
    For this purpose, you could try to use the example above to reproduce it.
    https://www.jqwidgets.com
    pagination for grid not working #111603
    wpd
    I am using Angular 8 and jqwidgets-ng 9
    [showheader]=”true” [pageable]=’true’ [sortable]=’true’ [filterable]=’true’ [enablebrowserselection]=”true” [pagesizeoptions]=”[’25’, ’50’, ’75’]” [pagesize]=”50″>
    </jqxGrid>
    const source: any = {
    localdata: this.allJobs,
    datatype: ‘json’,
    { name: ‘id’, type: ‘number’ },
    { name: ‘jobName’, type: ‘string’ },
    { name: ‘jobType’, type: ‘string’ },
    { name: ‘jobStat’, type: ‘string’ },
    { name: ‘site’, type: ‘string’ },
    { name: ‘cell’, type: ‘string’ },
    { name: ‘jobSubmitter’, type: ‘string’ },
    { name: ‘loadType’, type: ‘string’ },
    { name: ‘loadDate’, type: ‘date’ },
    { name: ‘lastLoadDate’, type: ‘date’ },
    { name: ‘payload’, type: ‘string’ },
    { name: ‘runLog’, type: ‘string’ },
    { name: ‘jobSize’, type: ‘number’ },
    { name: ‘jobDepK’, type: ‘number’ },
    { name: ‘runMsgLogX’, type: ‘string’ },
    { name: ‘statusColor’, type: ‘string’ }
    // console.log(source);
    this.jobStatusDataAdapter = new jqx.dataAdapter(source);
    // console.log(this.jobStatusDataAdapter);
    const statusrenderer = function(row, columnfield, value, defaulthtml, columnproperties, rowdata) {
    const theStatus = rowdata.jobStat;
    const statusColor = rowdata.statusColor;
    if (theStatus === ‘Failed’) {
    return ‘<div style=”display: inline-block; margin-top: 7px; color: ‘ + statusColor + ‘;”>’ + theStatus + ‘</div>’ +
    ‘<div style=”display: inline-block; margin-left: 5px; margin-top: 3px; cursor: pointer;” >’
    + ‘<i class=”material-icons” style=”color:’ + statusColor + ‘;”>error_outline</i></div>’;
    } else {
    return ‘<div style=”display: inline-block; margin-top: 7px; color: ‘ + statusColor + ‘;”>’ + theStatus + ‘</div>’;
    const linkDownload = function(row, columnfield, value, defaulthtml, columnproperties, rowdata) {
    return ‘<div style=”margin-left: 25px; margin-top: 3px; cursor: pointer;” class=”under-circle-green”>’
    + ‘<i class=”material-icons” style=”color:green;”>arrow_downward</i></div>’;
    this.jobStatusColumns =
    text: ‘Job Id’, datafield: ‘id’, width: ‘5%’,
    text: ‘Job Name’, datafield: ‘jobName’, width: ‘12%’,
    text: ‘Job Status’, datafield: ‘jobStat’, cellsrenderer: statusrenderer, width: ‘7%’,
    text: ‘Site’, datafield: ‘site’, width: ‘7%’,
    text: ‘Cell’, datafield: ‘cell’, width: ‘7%’,
    text: ‘JobSubmitter’, datafield: ‘jobSubmitter’, width: ‘8%’,
    text: ‘Log Files’, datafield: ‘runLog’, width: ‘5%’, cellsrenderer: linkDownload, filterable: false, hidden: true
    text: ‘LoadType’, datafield: ‘loadType’, width: ‘13%’,
    text: ‘Scheduled Date(GMT)’, datafield: ‘loadDate’, width: ‘13%’,
    text: ‘Completed Date(GMT)’, datafield: ‘lastLoadDate’, width: ‘10%’,
    text: ‘PayLoad File’, datafield: ‘payload’, width: ‘13%’,
    setTimeout(() => {
    // this.jobStatusGrid.applyfilters();
    if (sessionStorage.getItem(this.constant.USER_ROLE) === ‘Admin’ || sessionStorage.getItem(this.constant.USER_ROLE) === ‘Manager’) {
    this.jobStatusGrid.showcolumn(‘runLog’);
    this.jobStatusGrid.render();
    } else {
    this.jobStatusGrid.setcolumnproperty(‘jobSubmitter’, ‘width’, ‘13%’);
    }, 10);
    Please see the code
    pagination for grid not working #111649
    Hello wpd,
    I try to reproduce your case but there is missing information.
    The allJobs variable and also, the structure of your code.
    It seems that you use the mentioned code snippet in a function which could cause issues.
    I try to change it and the example seems to work fine with normalized scenario (if we avoid the missing data).
    Please, clarify it or it will be better to demonstrate your case in the stackblitz as on the end just use the Fork” option and share the link.
