jQuery UI Widgets Forums Grid pagesize and total
This topic contains 5 replies, has 2 voices, and was last updated by  lineker 11 years, 11 months ago.
  • pagesize and total #22642
    lineker
    ı am getting data with json to my grid.
    My pagesize is 50 default
    And I am fetching 50 records at each request.
    But total record number is 2560.
    I want to see as follow:
    0-50 / 2560
    How can I do it if I fetch 50 records at each request?
    What is the meaning of total below?
    my $result = { total => $total_records, //2560
    act => $data_list,
    success => JSON::true
    my $charset = $PARAM{CHARSET}{$lang};
    print $q->header(-content_type => “application/json; charset=$charset”);
    print to_json($result);
    pagesize and total #22647
    Please, look at this sample: http://www.jqwidgets.com/jquery-widgets-demo/demos/php/serverpaging.htm?web. It shows how to implement Server Paging.
    pagesize and total #22986
    lineker
    Thanks for link.
    I applied it but there is a problem.
    To be able to do it I am adding below code to my grid but this time filterable options, sort by ascending, descending dont work!
    virtualmode: true,
    rendergridrows: function()
    return dataAdapterGrid.records;
    pagesize and total #23115
    lineker
    Is there any solution for this?
    pagesize and total #23208
    lineker
    Is not there any solution for this.
    The thing I want is very basic
    I want to see total at my grig pagind but at the same time I want grid filter to work
    pagesize and total #23216
    lineker
    Hi
    I found the solution. I am using virtual mode but filter options are denone by me manually as follow;
    $(“#reportgrid”).on(“sort”, function (event) {
