jQuery UI Widgets Forums Grid Pager problem
This topic contains 3 replies, has 2 voices, and was last updated by  Dimitar 10 years, 1 month ago.
  • Pager problem #70052
    aser
    Hi, I have a problem with showing page size on pager. After switching page size it works fine.
    Grid load with parameters:
    pagesize: 14,
    pager
    Thanks.
    Pager problem #70056
    Hi aser,
    Could you, please, share your entire grid initialization code so that we may determine what causes this issue? Make sure you are using the latest version of jQWidgets (3.7.1).
    Pager problem #70059
    aser
    Yes, I’m using the latest version of jQWidgets (3.7.1).
    grid initialization parameters:
    width: ‘100%’,
    theme: ‘bootstrap’,
    enablehover: false,
    rowsheight:28,
    editmode: ‘dblclick’,
    autorowheight: true,
    showfilterrow: true,
    filterrowheight: 29,
    autoshowfiltericon: true,
    columnsheight:40,
    sortable: false,
    showsortmenuitems: true,
    columnsreorder: true,
    groupable: false,
    pagesize: 5,
    pagesizeoptions: [5, 10, 15],
    virtualmode: true,
    Pager problem #70093
    Hi aser,
    We could not reproduce the issue with the following example:
                var data = new Array();
                var firstNames =
                var lastNames =
                var productNames =
                var priceValues =
                // generate sample data.
                var generatedata = function (startindex, endindex) {
                    var data = {};
                    for (var i = startindex; i < endindex; i++) {
                        var row = {};
                        row["id"] = i;
                        row["price"] = price;
                        row["quantity"] = quantity;
                        data[i] = row;
                    return data;
                    datatype: "array",
                    localdata: {},
                    totalrecords: 1000000
                // load virtual data.
                    var data = generatedata(params.startindex, params.endindex);
                    return data;
                var totalcolumnrenderer = function (row, column, cellvalue) {
                    var cellvalue = $.jqx.dataFormat.formatnumber(cellvalue, 'c2');
                    return '<span style="margin: 6px 3px; font-size: 12px; float: right; font-weight: bold;">' + cellvalue + '</span>';
                $("#jqxgrid").jqxGrid(
                    width: '100%',
                    virtualmode: true,
                    pagesize: 5,
                        { text: 'Id', datafield: 'id', width: 50 },
                        { text: 'First Name', datafield: 'firstname', width: 120 },
                        { text: 'Last Name', datafield: 'lastname', width: 120 },
                        { text: 'Quantity', datafield: 'quantity', width: 100, cellsalign: 'right' },
                        { text: 'Unit Price', datafield: 'price', width: 100, cellsalign: 'right', cellsformat: 'c2' },
                        { text: 'Total', datafield: 'total', cellsrenderer: totalcolumnrenderer, cellsalign: 'right' }
        <div id="jqxgrid">
    Make sure you have implemented the rendergridrows callback function, which is necessary when virtualmode is enabled.
