jQuery UI Widgets Forums General Discussions Layouts Layout and Docking Layout Openlayers-Map is not working inside docking layout
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 8 years, 10 months ago.
  • Prashant
    Hi All,
    I am trying to integrate third party component into docking layout(Openlayers 3.0/Angular 2.0). I have created map component and integrate with Angular 2.0 RC5 and is working fine,then i tried to use same component in docking layout(Type : documentPanel) but map is not getting displayed in document panel.Only map div border and navigation buttons are displayed on screen.
    I have verified that,first map component is loaded and then generate docking layout. There is no error on browser console.
    Is there any technical issue with Angular 2.0(Openlayers) and Angular 2.0-RC5(Docking layout)?
    Any help would be appreciated,
    Prashant
    Hello Prashant,
    We do no have experience with this library.
    But I would like to focus the attention on this way how to initialize inner widget in “initContent”.
    Also load “ElementRef” from ‘@angular’ source. After this create element.
    Please, take a look this example and especially this part:
    let myTree: jqxTreeComponent = new jqxTreeComponent(new ElementRef(document.getElementById("Tree")));
    myTree.createWidget({ width: 190, source: source });
