jQuery UI Widgets Forums Grid Not able to hide column
This topic contains 4 replies, has 3 voices, and was last updated by  Peter Stoev 12 years, 7 months ago.
  • Not able to hide column #12008
    kartik.jajal
    I am not able to hide column of grid. i have written following code.
    $(“#jqxpurchasedetailgrid”).jqxGrid(
    width: 750,
    altrows: true,
    enabletooltips: true,
    { text: ‘Ref. No’, datafield: ‘referenceno’, width: 100 },
    { text: ‘Purchase No’, datafield: ‘purchaseitemno’, cellsalign: ‘right’, width: 100},
    { text: ‘T.Qty’, datafield: ‘totalqty’, cellsalign: ‘right’, width: 100},
    { text: ‘Item’, datafield: ‘itemname’, width: 250 },
    { text: ‘Item Amt’, datafield: ‘itemamount’, width: 100 },
    { text: ‘Other’, datafield: ‘others’, width: 200 },
    $(“#jqxpurchasedetailgrid”).jqxGrid(‘hidecolumn’,’purchaseitemno’);
    Not able to hide column #12014
    Hi kartik.jajal,
    If the data is still loading, you will not be able to hide the column. Call the hidecolumn method in the Grid’s ready callback or in the bindingcomplete event handler. Example: hideshowcolumns.htm.
    Not able to hide column #12072
    kartik.jajal
    thanks its working fine
    Not able to hide column #12909
    neong
    From the example hideshowcolumns.htm, only show to hide 1 column. Any way to hide more then 1 columns?
    Not able to hide column #12922
    Hi neong,
    Call the “hidecolumn” method for another column and you will hide it. In the example, the method is also dynamically called by checking/unchecking the checkboxes.
