jQuery UI Widgets Forums Grid Nest Grid button problem
This topic contains 1 reply, has 1 voice, and was last updated by  hardcode 12 years, 5 months ago.
  • Nest Grid button problem #12956
    hardcode
    I have a nest grid.. Just two levels and it works good. I want to render a button in the inner grid and when I do the rendering it appears however whenever I click on it then the button vanishes and displays its parents rowId.
    The parent grid so also have a column that have buttons and that works but the inner grid’s buttons does not work.
    Please advice on what is the problem and what you think I can do
    thanks
    Nest Grid button problem #12957
    hardcode
    hello,
    I have solved the problem
