jQuery UI Widgets Forums Grid Need to reassign recordsid after filter
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 12 years, 4 months ago.
  • Hi, I am having 5 records in grid .After filter the index of the records are not changing.How will i reassign the dataindex/uid/recordid after filter. Giving example of the grid data
    uid name age
    1 rajani 28
    2 mohan 28
    3 raj 27
    4 raja 29
    5 siva 30
    after filtering (siva) record became
    uid name age
    5 siva 30
    But it should be
    uid name age
    1 siva 30
    i need to make it reassign, if after filter 3 records are coming then it should be
    1
    2
    3.
    Please help.
    Rajani
    Hi Rajani,
    uid is used internally by the Grid. You should not change it or work with it. Please, use only the API available in the documentation.
