jQuery UI Widgets Forums Grid Need help with "clickable" checkbox
This topic contains 6 replies, has 2 voices, and was last updated by  dujmovicv 12 years, 6 months ago.
  • Need help with "clickable" checkbox #11236
    dujmovicv
    Hi All,
    please help me to resolve this small issue : I’ve set up a checkbox field in the grid which can be clicked to check or uncheck. When the chceckbox is blank (not checked) and I click on it, the php file is executing and the database record is being changed. When I refresh the page, the changes are there (i.e. the checkbox I’ve just clicked IS checked). The function is NOT working when I want to “uncheck” the record (set value to 0 in the database). It supposed to work cause almost everything is the same, except the script needs to set a value to ‘0’ instead of ‘1’
    Here’s the part of the js/php file:
    { name: 'id' },
    { name: 'task_name' },
    { name: 'task_description' },
    { name: 'task_cost_total' },
    { name: 'link_to_pr_task' },
    { name: 'planned_finish' },
    { name: 'finished' },
    { name: 'added_by' }
    url: '../grid/jqwidgets/controllers/tasks_on_pr_controller.php?action=<?=$action;?>',
    var data = "update=true&" + $.param(rowdata);
    dataType: 'json',
    data: data,
    and here’s the controller php file :
    if (isset($_GET['update']))
    // UPDATE COMMAND
    if ($_GET['finished'] == true) {
    $update_query_2 = "UPDATE tasks_on_project SET
    finished = '1'
    WHERE project_id = '".$project_id."' AND task_id = '".$_GET['id']."'";
    else {
    finished = '0'
    $result_2 = mysql_query($update_query_2) or die("SQL Error 1: " . mysql_error());
    echo $result_2;
    Please someone help me why it IS working for ‘true’ and not working ‘else’?
    By the way, the datafield for ‘finished’ is like :
    { text: 'Finished', datafield: 'finished', columntype: 'checkbox', width: 65 }
    and it has value 1 (checked) OR 0 (not checked)
    Thank you in advance!!!!!
    Need help with "clickable" checkbox #11238
    Hi dujmovicv,
    What is the value of $.param(rowdata) when you uncheck the checkbox?
    Do you use jQWidgets 2.5? If you do, then you are missing the last parameter of the updaterow callback function and especially the commit parameter which represents a callback function. In the ajax’s success, call commit(true), else on error, call commit(false).
    Best Wishes,
    Need help with "clickable" checkbox #11245
    dujmovicv
    No, I’m using 2.4.2
    Is there a way to check the value of $.param(rowdata)? Maybe in the browser console?
    Thank you for helping me 🙂
    Need help with "clickable" checkbox #11246
    In the browser console or with a simple alert. See here: http://api.jquery.com/jQuery.param/
    Best Wishes,
    Need help with "clickable" checkbox #11272
    dujmovicv
    I’ve managed to retrieve the $.param(rowdata) values and now I’m even more confused…. The ‘finished’ value is passed correctly : it is ‘true’ when checked and ‘false’ when unchecked.
    I modified my php to :
    finished = '1'
    WHERE project_id = '".$project_id."' AND task_id = '".$task_id."'";
    if ($_GET['finished'] == false) {
    finished = '0'
    It does NOT work when finished=false
    What am I doing wrong???
    Need help with "clickable" checkbox #11273
    May be it should be $_GET[‘finished’] == ‘true’ and $_GET[‘finished’] == ‘false’.
    Best Wishes,
    Need help with "clickable" checkbox #11275
    dujmovicv
    Heh, that was it!!!! Totally confused me that is WAS working with just true and wasn’t with false… Thanks Peter, you’re the man!
