jQuery UI Widgets Forums Navigation Menu, Context Menu Need help with a menu issue
This topic contains 4 replies, has 1 voice, and was last updated by  ohioguy67 12 years ago.
  • Need help with a menu issue #23447
    ohioguy67
    Hi. I am trying to create a main menu for my application. I want one of the menu options to br ing up a submenu that has checkboxes next to the items. I need to keep the submenu options in the javascript section so I’ve made the submenu a jqxlistbox object. The problem I’m having is that when the submenu is displayed, its size seems to be fixed and I can’t find a way to change it (so any long entries in the jqxlistbox are cut off). Here’s the code so far:
    Test
    var theme = ‘base’;
    $(“#jqxMenu”).jqxMenu({ width: ‘200’, height: ’30px’, theme: theme });
    $(‘#jqxMenu’).on(‘itemclick’, function (event)
    // get the clicked LI element.
    var element = event.args;
    alert(element.id);
    var listSource = [{ label: ‘Field 1’, value: ‘name’, checked: false }, { label: ‘Field 123456789012345’, value: ‘type’, checked: true }
    $(“#jqxlistbox”).jqxListBox({ source: listSource, width: 200, height: 100, theme: theme, checkboxes: true });
    $(“#jqxlistbox”).on(‘checkChange’, function (event) {
    alert(event.args.value);
    Home
    Settings
    Option 1
    Option 2
    List
    Can you please tell me what I’m doing wrong?
    Need help with a menu issue #23451
    ohioguy67
    Trying to put code in with each line commented so it shows up here:
    <!– Test –>
    <!– Home –>
    <!– Settings –>
    <!– Option 1 –>
    <!– Option 2 –>
    <!– List –>
    Need help with a menu issue #23454
    ohioguy67
    Well I can’t seem to get the code to display here. Is there a way to paste it so it’s not interpreted as HTML?
    Need help with a menu issue #23493
    ohioguy67
    Ok, I’m trying one more time with all the brackets removed.
    !DOCTYPE html
    html lang=”en”
    head
    title Test title
    link rel=”stylesheet” href=”jqwidgets/styles/jqx.base.css” type=”text/css” /
    script type=”text/javascript” src=”jquery-1.9.1.min.js” script
    script type=”text/javascript” src=”jqwidgets/jqxcore.js” script
    script type=”text/javascript” src=”jqwidgets/jqxdata.js” script
    script type=”text/javascript” src=”jqwidgets/jqxbuttons.js” script
    script type=”text/javascript” src=”jqwidgets/jqxscrollbar.js” script
    script type=”text/javascript” src=”jqwidgets/jqxlistbox.js” script
    script type=”text/javascript” src=”jqwidgets/jqxdropdownlist.js” script
    script type=”text/javascript” src=”jqwidgets/jqxmenu.js” script
    script type=”text/javascript” src=”jqwidgets/jqxpanel.js” script
    script type=”text/javascript” src=”jqwidgets/jqxcheckbox.js” script
    var theme = ‘base’;
    alert(element.id);
    script
    head
    body
    div id=’jqxMenu’
    ul
    li Home li
    li Settings
    ul
    li id=’opt1′ Option 1 li
    li id=’opt2′ Option 2 li
    li List
    ul
    li style=’margin:0px; padding:0px’ div id=’jqxlistbox’ div li
    ul
    li
    ul
    li
    ul
    div
    body
    html
    Need help with a menu issue #23494
    ohioguy67
    Hooray it worked (except it lost all the indentation). I’m going to create a new post so that it’s clearer. Please disregard this one.
