jQuery UI Widgets › Forums › Layouts › Splitter › Navigation with jqxSplitter and jqxTree
This topic contains 2 replies, has 2 voices, and was last updated by Peter Stoev 12 years, 2 months ago.
In demos under jqxSplitter, there is a sample for ‘Integartion with jqxTree (navigation.html)’. This program works fine.
I tried to modify this program like instead showing the elements name, i had tried to create different buttons on tree item click/selection.
Like for example, On selection of ‘Today’ it should display ‘save’ button and on selection of ‘Contacts’ it should display ‘quit’ button. It displays the buttons. But it is not considereing the theme set for it. i.e. it does not include the id. Can you please help me resolve this issue. Below is the code.In this sample is demonstrated how to create a basic navigation
with jqxTree and jqxSplitter.$(document).ready(function () {
var theme = ‘ui-redmond’;
// Create jqxTree
$(‘#jqxTree’).jqxTree({ theme: theme, height: ‘100%’, width: ‘100%’ });
$(“#splitter”).jqxSplitter({ theme: theme, width: 650, height: 400, panels: [{ size: 250}] });$(‘#jqxTree’).bind(‘select’, function (event) {
var args = event.args;
var item = $(‘#jqxTree’).jqxTree(‘getItem’, args.element);if(item.label == ‘Today’)
alert(item.label);
//create buttons
$(‘#saveButton’).jqxButton({ theme: theme, width: ’70px’ });
$(“#ContentPanel”).html(” Today “);}
if(item.label == ‘Contacts’)
alert(item.label);
//create buttons
$(‘#quitButton’).jqxButton({ theme: ‘ui-redmond’, width: ’70px’ });
$(“#ContentPanel”).html(“”);
//$(“#ContentPanel”).html(“” + event.args.element.id + ““);
});Mail
Calendar
Contacts
Inbox (3)
jQWidgets
Admin
Corporate
Finance
Other
Personal
Deleted Items (10)
Today
Last Week
Last Month
Notes
Settings
Favorites
Shalini S.$(document).ready(function () {
// Create jqxTree
alert(item.label);
//create buttons
alert(item.label);
//create buttons
});Hi shalini,
Did you include the jqx.ui-redmond.css in your project?
