jQuery UI Widgets › Forums › Grid › Multi-level grid error
Tagged: Assembling N-Nested jQuery Grid, grid, jqxgrid, n-nested, nested grids, Theme
This topic contains 9 replies, has 2 voices, and was last updated by baha2jo 10 years, 8 months ago.
AuthorMulti-level grid error Posts
Hello everybody,
I’m trying to create a nested gridview and i followed the following tutorial http://www.jqwidgets.com/assembling-n-nested-jquery-grid/ but i got this error : Uncaught ReferenceError: theme is not defined ,and nothing loaded in the browser. Please help me
thanks
Hello baha2jo,
You would have to define a variable named theme and set it to “darkblue”.
http://www.jqwidgets.com/Hii
Thanks for your response ,after solving “theme” issue i got this “Error: Invalid Selector – #jqxgrid! Please, check whether the used ID or CSS Class name is correct.” ,is this happin because i’m using a different version of jQwidgets ??
Hi baha2jo,
No, this error is thrown because you do not have a div with id=”jqxgrid”. Maybe you have one with id=”jqxGrid” or you do not have a grid initialization div at all.
http://www.jqwidgets.com/Here is my code :
<html lang=”en”>
<head><link rel=”stylesheet” href=”../../jqwidgets/styles/jqx.base.css” type=”text/css” />
<link rel=”stylesheet” href=”../../jqwidgets/styles/jqx.darkblue.css” type=”text/css” />
<!–<script src=”http://ajax.googleapis.com/ajax/libs/jquery/1.9.1/jquery.min.js”></script> –>
<script type=”text/javascript” src=”../../scripts/jquery-1.7.2.min.js”></script>
<script type=”text/javascript” src=”../../jqwidgets/jqxgrid.selection.js”></script><script type=”text/javascript”>
var data = new Array();
var firstNames =
“Andrew”, “Nancy”, “Shelley”, “Regina”, “Yoshi”, “Antoni”, “Mayumi”, “Ian”, “Peter”, “Lars”, “Petra”, “Martin”, “Sven”, “Elio”, “Beate”, “Cheryl”, “Michael”, “Guylene”
var lastNames =
“Fuller”, “Davolio”, “Burke”, “Murphy”, “Nagase”, “Saavedra”, “Ohno”, “Devling”, “Wilson”, “Peterson”, “Winkler”, “Bein”, “Petersen”, “Rossi”, “Vileid”, “Saylor”, “Bjorn”, “Nodier”
var productNames =
“Black Tea”, “Green Tea”, “Caffe Espresso”, “Doubleshot Espresso”, “Caffe Latte”, “White Chocolate Mocha”, “Cramel Latte”, “Caffe Americano”, “Cappuccino”, “Espresso Truffle”, “Espresso con Panna”, “Peppermint Mocha Twist”
var priceValues =
“2.25”, “1.5”, “3.0”, “3.3”, “4.5”, “3.6”, “3.8”, “2.5”, “5.0”, “1.75”, “3.25”, “4.0”
for (var i = 0; i < 10; i++) {
var row = {};
row[“firstname”] = firstNames[Math.floor(Math.random() * firstNames.length)];
row[“lastname”] = lastNames[Math.floor(Math.random() * lastNames.length)];
row[“productname”] = productNames[productindex];
row[“price”] = price;
row[“quantity”] = quantity;
row[“total”] = price * quantity;
data[i] = row;
localdata: data,
datatype: “array”
};// set rows details.
$(“#jqxgrid”).bind(‘bindingcomplete’, function (event) {
if (event.target.id == “jqxgrid”) {
$(“#jqxgrid”).jqxGrid(‘beginupdate’);
var datainformation = $(“#jqxgrid”).jqxGrid(‘getdatainformation’);
for (i = 0; i < datainformation.rowscount; i++) {
var hidden = i > 0 ? true : false;
$(“#jqxgrid”).jqxGrid(‘setrowdetails’, i, “<div id=’grid” + i + “‘ style=’margin: 10px;’></div>”, 220, hidden);
$(“#jqxgrid”).jqxGrid(‘endupdate’);
var theme=”darkblue”
// creage jqxgrid
width: 670,
height: 365,
rowdetails: true,
initrowdetails: initlevel2,
{ text: ‘First Name’, dataField: ‘firstname’, width: 100 },
{ text: ‘Last Name’, dataField: ‘lastname’, width: 100 },
{ text: ‘Product’, dataField: ‘productname’, width: 180 },
{ text: ‘Quantity’, dataField: ‘quantity’, width: 80, cellsalign: ‘right’ },
{ text: ‘Unit Price’, dataField: ‘price’, width: 90, cellsalign: ‘right’, cellsformat: ‘c2’ },
{ text: ‘Total’, dataField: ‘total’, cellsalign: ‘right’, minwidth: 100, cellsformat: ‘c2’ }
});var initlevel2 = function (index) {
var grid = $($.find(‘#grid’ + index));
grid.bind(‘bindingcomplete’, function (event) {
if (event.target.id == “grid” + index) {
grid.jqxGrid(‘beginupdate’);
var datainformation = grid.jqxGrid(‘getdatainformation’);
for (var i = 0; i < datainformation.rowscount; i++) {
var hidden = true;
grid.jqxGrid(‘setrowdetails’, i, “<div id=’subgrid” + i + “‘ style=’margin: 10px;’></div>”, 220, hidden);
grid.jqxGrid(‘endupdate’);
if (grid != null) {
grid.jqxGrid({ rowdetails: true, initrowdetails: initlevel3, source: dataAdapter, theme: theme, width: 600, height: 200,
{ text: ‘Quantity’, dataField: ‘quantity’, cellsalign: ‘right’ }
}var initlevel3 = function (index) {
var grid = $($.find(‘#subgrid’ + index));
if (grid != null) {
grid.jqxGrid({ source: dataAdapter, theme: theme, width: 530, height: 200,
}</script>
<body class=’default’>
<div id=”jqxgrid”>
</html>Hi baha2jo,
Your script must be in $(document).ready(). We suggest you take a look at the jqxGrid Getting Started guide to learn the basics of jqxGrid use.
http://www.jqwidgets.com/Thanks for your help ,it works but only dispalys the root level in the grid ,what should i do to display the sub grid.
I will read the guide ASAP .Thanks again,
Hi baha2jo,
Please try the following, updated, version of the example in the blog post: http://www.jqwidgets.com/community/topic/getting-error-with-assembling-n-nested-jquery-grid/#post-56402.
http://www.jqwidgets.com/Thanks alot for the help
