jQuery UI Widgets Forums Grid move away from cell on button click
This topic contains 1 reply, has 2 voices, and was last updated by  admin 9 years, 3 months ago.
  • move away from cell on button click #82857
    shawn
    I have a grid with editable fields in it.
    Also on each row is a “save” button, that saves that row’s data when clicked.
    My problem, is that if the user is in the middle of editing a cell (hasn’t moved off or away from the cell), and they click “save”, that cell’s values do not change.
    How can I force the focus away from the edited cell when the save button is clicked, so that the changes are committed?
            { name: 'rID', type: 'string' },
            { name: 'rName', type: 'string' },
            { name: 'rTitle', type: 'string' },
            { name: 'rPhone', type: 'string' },
            { name: 'rEmail', type: 'string' }
        localdata: jc
    // init the grid
    $("#roster").jqxGrid(
        width: 800,
        height: 300,
          { text: 'ID', datafield: 'rID',width: "7%",editable: false},
          { text: 'name', datafield: 'rName',width: "21%",editable: true},
          { text: 'title', datafield: 'rTitle',width: "19%",editable: true},
          { text: 'phone', datafield: 'rPhone',width: "17%",editable: true},
          { text: 'email', datafield: 'rEmail',width: "20%",editable: true},
    			{ text: 'save', datafield: 'edit', width: "8%",  columntype: 'button',
    				     cellsrenderer: function () {
                 		return "Save";
              		var dataRecord = $("#roster").jqxGrid('getrowdata', row);
              		saveRoster(dataRecord.rID,dataRecord.rName,dataRecord.rTitle,dataRecord.rPhone,dataRecord.rEmail);
    			{ text: 'delete', datafield: 'delete', width: "8%",  columntype: 'button',
                 		return "Delete";
              		var ndx=selectedrowindex = $('#roster').jqxGrid('selectedrowindex');
              		delRoster( dataRecord.rID,ndx);
    move away from cell on button click #82878
    admin
    Hi shawn,
    You will probably need to use the Grid’s events about editing and end the editing before you save.
