jQuery UI Widgets Forums Editors DateTimeInput Mobile DateTimeInput Grid problem
This topic contains 6 replies, has 2 voices, and was last updated by  FernandoCastro 9 years, 4 months ago.
  • Mobile DateTimeInput Grid problem #80328
    FernandoCastro
    I manage to put working jqwidgets example jqxDateTimeInput for mobile.
    I also put work a mobile grid showing my data from a postgresql.
    What I can not achieve is to make my jqxDateTimeInput page call the grid mobile page.
    I want to use jqxDateTimeInput to select date time interval and then show my data on a grid.
    Can any one please post an example how jqxDateTimeInput “calls” mobile grid page??
    Thank You very much
    Fernando Castro
    Mobile DateTimeInput Grid problem #80338
    Hi Fernando Castro,
    Your problem does not seem to be related to our widgets. You may probably use jQuery’s AJAX function to make page calls.
    Mobile DateTimeInput Grid problem #80347
    FernandoCastro
    Thank you for your reply.
    Yes I am using AJAX post function. Is that not suposed to work?
    Here is my code (part of it on one attempt …)
    $(“#search”).bind(‘click’, function () {
    type:”POST”,
    url : ‘${pageContext.request.contextPath}/Mgrid.htm’,
    data : $(‘#formname’).serialize(),
    success : function(response) {
    alert(response);
    I know that it “calls” Mgrid.htm because I have a log but it does not open Mgrid.htm page in the browser.
    (Mgrid.htm is just a copy of jqwidgets grid.htm in order to avoid other “noise”…)
    Thank You Very much
    Fernando Castro
    Mobile DateTimeInput Grid problem #80358
    Hi Fernando Castro,
    Making AJAX call never opens another web page. It sends some data to another page. If you want to open a web page, use window.open.
    Mobile DateTimeInput Grid problem #80360
    FernandoCastro
    My problem is that I must call a servlet and my servlet should open another page…
    Can you please just gave me a tip how to do it??
    Tnhak you very much
    Fernando
    Mobile DateTimeInput Grid problem #80361
    Hi Fernando Castro,
    Calling servlet is not a function of our product. Unfortunately, I cannot help with this one.
    Mobile DateTimeInput Grid problem #80362
    FernandoCastro
    ok Peter,
    thanks any way for your help 🙂
