jQuery UI Widgets Forums Lists ComboBox method val issue
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 12 years, 6 months ago.
  • method val issue #12512
    marchip
    Hi
    I have a problem with method val. It’s return always undefined.
    I have added this code to demos/jqxcombobox/setting.htm page of your zip:
    function test()
    var value = $(“#jqxComboBox”).jqxComboBox(‘val’);
    alert(value);
    this function is called when a button is pressed
    alert show always undefined
    I’ve autocomplete enabled
    method val issue #12528
    Hi marchip,
    The functionality requires jQWidgets ver. 2.5.5. Please, check the header of any js file in the download package whether you use the correct version. If you use a previous one, you should update in order to use the ‘val’ method.
